Thu, Jan 9, 8:39 AM CST
Subject: Having difficulty with Morphs
Amanodel ( ) posted Wed, 25 February 2009 at 12:20 AM · edited Wed, 08 January 2025 at 8:34 PM
Okay I can't seem to figure out the morphs >.< How do i apply them to Victoria 3 and I'm using Poser 6
ratscloset ( ) posted Wed, 25 February 2009 at 1:12 AM
Most Morphs Inject into the figure from the Pose Library. These will add Dials to the Figure that allow you to use the Morph.
Sometimes you need to change Body Part after injecting to see the Morphs if your Display does not update.
ratscloset
aka John
Amanodel ( ) posted Wed, 25 February 2009 at 1:15 AM
Okay what do you mean by change the body part? And where do the dials show up at? I hate to say it, because I'm usually a fairly smart person, but would you explain it to me as if you were explaining it to a seven year old child?
ratscloset ( ) posted Wed, 25 February 2009 at 1:26 AM
In the Parameters (Object> Properties will open the Properties Tab, Window> Parameters will open the Parameters Tab if it is not already open) The Parameters is where there are the Dials for Bending the Body Parts.. there you will see the Morphs Dials when added. To change Body Part, if you have the Body Selected, change to Head, then go back to Body and you should see a bunch of Dials added if they were not there before. NOTE: Use the Morphs on the Body and Heads, not the individual Body Parts for the most part... *There are exceptions...
I recommend to Load all the Body Morphs using the one Thumbnail if you are using DAZ Morphs. (also load all the Head Morphs using that one Thumbnail) The various Specific Morphs are all included and it will let you know what you have available and allow you to see what each one does. Once you understand what they each do, then you can delve in deeper.
ratscloset
aka John
hborre ( ) posted Wed, 25 February 2009 at 1:05 PM
Make sure you have purchased the morph package for Vicky and have it correctly installed.  Otherwise, you will be looking for morph dials that don't exist for your model.
Amanodel ( ) posted Fri, 27 February 2009 at 7:18 PM
Morph package for Vickey... as in make sure the morphs I'm buying are for Vicky? Or another application that will allow me to use morphs?
hborre ( ) posted Sat, 28 February 2009 at 6:17 PM
DAZ3D sells a head & body morph package for Vicky 3 which is the core content for changing her head & body shape.  The link is below:
http://www.daz3d.com/i/3d-models/morphs/victoria-3-0?item=3008&cat=62&_m=d
By having this core content present in the main Poser runtime, any character content you apply will refer to these 'morph' files to physically change the model's characteristics.  Usually, these morph files can be found in the Pose folder of your library.
Amanodel ( ) posted Sun, 01 March 2009 at 9:18 AM
Thank you so much ^_^ At the moment my computer is havingdifficulties but as soon as it decides to behave this should fix alot of problems. Thanks. thanks her lucky stars that her roommate let's her borrow her laptop
Amanodel ( ) posted Tue, 22 November 2011 at 4:16 PM
I finally got my computer back, and have since moved it to my desktop. Thank you everyone for helping me so much and thank you for the link. It turns out my problem was that I don't have the morph set for that model.
Feels really silly now
But i discovered that I had bought the Morphing Fantasy Dress and have been playing with that. ^^;;
But next Paycheck I'll definitely be buying The Morph for V3. ^_^ Thank you all very much for your help.
