Tue, Nov 19, 6:34 PM CST
Subject: Light Rotation
ghost6677 ( ) posted Fri, 27 February 2009 at 7:30 AM · edited Tue, 19 November 2024 at 6:32 PM
Hello,
i was wondering how to rotate a complete light set. (i cant parent infinite lights so i cant use a "prop" trick :( ).
I wondered whether there is a python script out there that can rotate lights around y axis for example?
Allready searched google and freebiesection but found nothing.
Best Regards.
raven ( ) posted Fri, 27 February 2009 at 9:38 AM
Actually, you can parent infinites via a workaround. Load the prop, select your infinite light, in the parameters panel, change it to a spotlight. Parent it to the prop, then change it back to an infinite light.
Job done :)
ghost6677 ( ) posted Fri, 27 February 2009 at 11:58 PM
Didnt thought of that... well, sounds quite easy, must give it a try :D Thanks for the immediate help!
EricJ ( ) posted Sat, 28 February 2009 at 1:00 AM
There's a python script called "LightPanel" that will allow you to parent any light to anything.
I parent the lights to the ground and then I can rotate the lights by rotating the ground.
The script is in the free stuff.
