Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 10:35 am)
They have transparency maps on them. This allows certain areas to be transparant while adding depth to the textures especially hair!).
3-D Arena | Instagram | Facebook
I do not feel obliged to believe that the same
God who has endowed us with sense, reason, and intellect has
intended us to forgo their use.
-Galileo
Yes, its the transparancy in the Render / Materials settings - the small dots indicate the degree of transparancy as set on the two sliders (minimum and maximum) - If you set both sliders to zero (for all materials in the object) - you will be able to see the object in the preview window (but without the effect of trnasparancy).
Or you can select the piece of clothing/hair that is showing as transparent and then go to the Display menu and select "figure style -> cartoon" for an entire clothing figure or conforming hair or "element style -> cartoon" for a hair prop or just part of a clothing item etc. All the transparencies and textures will still be there when you render, but the object will look solid while you're trying to pose it. - Mark
Mark
Hi, Just curious why it is that some items when placed on a model are nearly invisible and others aren't. I bought the Vicky Cocktail dresses and Nightlife shoes from DAZ3D. The shoes show up just fine. The dresses are nearly invisible except for the tiny dots that make up its outline. This is also true with Total Hair. Once they are rendered, they look great and my hats off to those who made these items. Wonderful job! But just wanted to know why they are invisible and whether or not they can be made to show? Kinda difficult for me to set them up as they are and with my system, render times can become a bit long. Thanks! Nebula
