Wed, Feb 5, 12:27 AM CST
Subject: Poser Unusual Error
Hdrider ( ) posted Tue, 03 March 2009 at 10:02 AM · edited Wed, 05 February 2025 at 12:25 AM
Hello,
All of a sudden I started to get this error. It's not consistent. Only certain files.
Anyone know what is causing this and how to fix it??
Thanks...
No good deed goes unpunished ...
CaptainJack1 ( ) posted Tue, 03 March 2009 at 10:21 AM
When I have that happen, it usually means that one of my USB drives is disconnected. You might try physically reconnecting any you have, and do a re-boot.
Another possibility is that the place where the original library pointed to has been moved. Done any hard-drive-type housecleaning lately?
thefixer ( ) posted Tue, 03 March 2009 at 11:12 AM
I've had this before, can't remember what it was, I think a reinstall of the offending file worked though!
Injustice will be avenged.
Cofiwch Dryweryn.
Gareee ( ) posted Tue, 03 March 2009 at 12:28 PM
Yep.. I think poser is looking for a additional runtime that's been changed moved, or removed. Poser needs all the runtimnes available on boot. Never change them without first removing them from the current runtime list.
thefixer ( ) posted Tue, 03 March 2009 at 12:32 PM
I've had that same message, it wasn't a runtime issue in my case because I only have the one and it's always been in the same place.
Not saying it's not that in your case, just saying it could be either or!!
Cofiwch Dryweryn.
Hdrider ( ) posted Tue, 03 March 2009 at 6:45 PM
Okay, all of my drives are up and running. I did a little experimenting. I opened the cr2 file I was getting the error on and manually directed the obj and texture files to the Poser folders. That worked. Next, I used the original file and noticed in was looking for some texture files that didn't exist. I removed the references and it worked also. The thing is, this never happened before. Poser just asked for the texture file.
Anyways, just another mystery.
Later...Still digging...
