Mon, Jan 20, 1:15 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Can someone write me a script... Java, python... something?
Conniekat8 ( ) posted Fri, 13 March 2009 at 3:10 PM · edited Mon, 20 January 2025 at 1:06 PM
I need a script of some sort that I can run in Windows, or DOS, independent of any other apps.
It needs to import UV Mapping and grouping from a base OBJ file into a morphed OBJ file. It needs to be able to do it for a whole list (directory) of files.
For example, 100 morphs, one base file.
Doesn't need a fancy interface. I gather this is pretty simple thing for someone whom knows how to program.
50 Bucks paid via paypal or a gift cert On Rendo or DAZ - your choice, plus, three of my products, current or save for future releases.
nruddock ( ) posted Fri, 13 March 2009 at 5:25 PM
Just so things are clear, what you want is a script to do the equivalent of UVMapper's import UVs function i.e. restore the grouping so that you can make morphs (as per -> http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2759444) ?
The easiest two languages to do this would be PERL or Python, but you'd need to install the standalone interpreters to use them from the command line (however a Python script could use Poser's built-in interpreter, but would need a simple GUI to collect arguments).
The other important thing is what location and naming convention do you want for the output files ?
Choices are :-
  1. Add some suffix to the name, e.g. "-morph" in the same directory as the original
  2. Put output files in a new subdirectory either in the original directory, or a new one at the same level but named appropriately, and with or without a suffix on the output files.
svdl ( ) posted Fri, 13 March 2009 at 6:05 PM
Hmm.
I'm a bit rusty when it comes to PoserPython, but it is probably the easiest way.
Procedure:
  • specify the base OBJ using a dialog box;;
  • specify the morphed OBJ folder using a dialog box;
  • for each OBJ file in the directory containing the morphed OBJs
           - import the base object into Poser using code; no scaling.
           - load the OBJ as morph onto the base object;
           - set the dial value to 1.000
           - export the morphed OBJ from Poser, including grouping
           - delete the morphed OBJ from the scene
  • notify completion.
My gallery   My freestuff
nruddock ( ) posted Fri, 13 March 2009 at 6:31 PM
That looks right, although I think there are advantages to taking a text processing approach to the problem.
markschum ( ) posted Fri, 13 March 2009 at 10:43 PM
The morphed object is identical to a master object except for vertex positions ?
so you could just replace the master obj vertex entries with the morphed object vertex entries ?
Poser python can certainly handle that , and the dialogs in poser 7 would make it fairly easy to get the original folder name .
markschum ( ) posted Wed, 18 March 2009 at 11:24 AM
Has anyone done this request ?
nruddock ( ) posted Wed, 18 March 2009 at 3:19 PM
Quote - Has anyone done this request ?
Not yet.
PhilC ( ) posted Wed, 18 March 2009 at 3:44 PM · edited Wed, 18 March 2009 at 3:45 PM
I do not often read the forum front page but just saw this post bumped to the top.
Conniekat8 emailed me directly, probably at the same time as making the post.
I emailed a script back later the same evening.
Yes it is just basic text manipulation, swapping out the vertices lines from the morphed OBJ back to the original.
markschum ( ) posted Wed, 18 March 2009 at 4:20 PM
ok, thanks , I just wanted to check before I started on it .
