Mon, Nov 18, 2:29 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 18 12:40 pm)
Subject: B&W rendering
mdiramali ( ) posted Sun, 15 March 2009 at 4:27 AM · edited Mon, 18 November 2024 at 11:55 AM
Is there an easy way for B&W rendering in poser?
raven ( ) posted Sun, 15 March 2009 at 7:52 AM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2754029&page=1
Check out this thread. About two thirds of the way down, bagginsbill tells how to set up a 'lens' in front of the camera which you can use to get all jkinds of effects, black and white being one of them.
bagginsbill wrote:
The basic setup is very simple.
Load a one-sided square. Scale it up so it is like a screen hanging in front of your whole scene, between the camera and the subject. This is your "lens". You cannot see the scene directly anymore, only through the lens.
Set the square properties to no shadow, and not visible in raytracing.
Go into the material room for the lens (the square).
Set Diffuse_Value=0, Specular_Value = 0.
Add a Refract node and plug it into Alternate_Diffuse. (Or if you prefer, use one of the two-knob channels such as Ambient or Refraction. With such channels, you can have separate controls (and potentially nodes) on the color and the brightness.)
Set the Refract IOR = 1.0.
At this point you can render and your original scene should appear unchanged. You have a neutral lens. Save this in your library for future use as a starter.
Then you go from there playing with the effects.
For example, put an HSV node between the Refract and the root node. Now you can adjust hue, saturation, and brightness for the entire scene. Not only does this simple setup give you many artistic options, but you can also adjust your LIGHT LEVELS all from this one place: HSV.Level.
After you get the hang of that you can start doing more tricky stuff between the Refract node and the root node.
Hope that helps.
pjz99 ( ) posted Sun, 15 March 2009 at 8:27 AM
You could also just desaturate the render in postwork, or use the image adjustment "Black and White" in newer versions of Photoshop and similar image editors...
My Freebies
Dave-So ( ) posted Sun, 15 March 2009 at 10:33 AM
or go over to RDNA and buy Poser Render Studio Expansion 1 - Monochrome
http://www.runtimedna.com/mod/bcs/index.php?ViewProduct=3477&TopID=174174
does not require Poser Render Studio
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
IsaoShi ( ) posted Sun, 15 March 2009 at 11:35 AM
Eeek! 25 dollars. That's nearly 18 of my pound thingies these days.
But it looks like you get a lot of stuff.
Does anyone have it? Is it good value? I have a lot of respect for semidieu, so I suppose I shouldn't really need to seek assurance. All the same....
