Thu, Nov 14, 3:10 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: A little help please
Moonbow ( ) posted Sun, 15 March 2009 at 1:05 PM · edited Thu, 14 November 2024 at 3:00 AM
Hello all,
I have been busy for some time and finially am able to get back to using Poser. I am using Poser5 and trying to learn how to work with it. My major problem right now is the window with the model in it keeps moving up in to the top right hand corner and I have no idea how to move it back to where it belongs. I don't even know why it moves. Any help will be greatly appreciated.
Thank you
Moonbow
markschum ( ) posted Sun, 15 March 2009 at 1:17 PM
that window is floating and can be moved by grabbing the top of it and dragging [left mouse and drag]
ockham ( ) posted Sun, 15 March 2009 at 1:38 PM
If it keeps going back to the same location after you pull it,
could be a problem with the file Poser.ini.
Try deleting the file and restarting Poser.  This will put everything
to default locations and will write a new Poser.ini file.  This
sometimes helps.
If you're using Vista, you could be having access limitations,
because the typical Poser installation is inside Program Files
which has tight limits.  I don't know if this would affect the INI
file, but it's a general problem.
Be sure Poser has maximum access, or move the whole setup
to a location outside Program Files, such as C:Poser 5.
My python page
My ShareCG freebies
Moonbow ( ) posted Sun, 15 March 2009 at 5:16 PM
Thank you both for your replies. I will try what you have suggested.
Thank you
Sandra
TrekkieGrrrl ( ) posted Sun, 15 March 2009 at 5:58 PM
 Isnt' that a fairly known bug in Poser 5? I remember it. The best way of fixing the situation is to set a Memory Dot when the workspace looks like you want it to, and then make sure the memory dots is placed where they won't be obscured next time the window goes North.
Thing is I would have sworn it used to go to the top LEFT corner. But then it's been ears since I used P5, so I may remember it wrong.
(PS.: to all old P5 users.. am I the only one who still gets a moment of panic whenever I've selected the Left Forearm and see it on the parameter dials?)
markschum ( ) posted Sun, 15 March 2009 at 6:29 PM
I started with Poser 5 and service pack 2. I didnt notice the bugs that other users had reported.
Moonbow ( ) posted Mon, 16 March 2009 at 7:19 AM
My goodness Trekkiegrrrl! You are absolutly right...it is the upper left it goes to lol! I seem to have fixed it thanks to all the help I have recieved here. Thank you all!
Moonbow
