Sun, Nov 24, 4:07 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Mirror Groups?
shadownet ( ) posted Sat, 28 March 2009 at 11:00 AM · edited Thu, 21 November 2024 at 7:10 PM
Hi,
I often use the grouping tool in Poser to set up my mesh groups. Often the grouping on one side  for things like arms and legs could be the same for the other.  It would be a real time saver if I could group, say the rForeArm and then transfer that grouping over to lForeArm, and so on.  Does anyone know of a python script or utility to do this?
Thanks in advance,
Rob
nruddock ( ) posted Sat, 28 March 2009 at 11:29 AM
Attached Link: http://ockhamsbungalow.com/Python/
ockham did a script called "Group Mirror" which I believe does what you want.
shadownet ( ) posted Sat, 28 March 2009 at 11:48 AM
Wow! thanks! That is exactly what I was looking for! :O)  Good ol ockham to the rescue!  Thanks for the link to his pythons as well as I see several others I would find useful!  :O)
