Sat, Jan 11, 9:07 AM CST
Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Jan 05 8:10 pm)
Check out the
Subject: Someone's turning 2D photos to 3D models!
warewullf ( ) posted Wed, 08 April 2009 at 4:35 AM · edited Wed, 08 January 2025 at 8:59 AM
I've seen a few websites offer this service. Taking your 2D photos and tuning them to 3D models to be engraved in crystal.
www.sub-laser.co.uk/shop/photo-gift/3D-Photo-Couple-Block-Large
More info:
www.sub-laser.co.uk/shop/support/index.php
Does anyone have any idea how they might be doing this? I find it hard to believe that they are individually modelling each and every photo they recieve. I work in the crystal imaging business and I've never seen any software that will turn 2D to 3D easily enough to be a viable and profitable service. I suspect they have some bit of software I'm not familiar with.
Anyone got any ideas as to what it might be?
Hoofdcommissaris ( ) posted Wed, 08 April 2009 at 6:25 AM
 It looks like they use the photo as a height map. The lighter the pixel, the more to the front it is positioned. Portraits will have to be lighted equally, to prevent strange deforming (for instance when the face is partly in the shadow).
Lots of 3D software can generate an object with help of a height map / bump map and export an obj or 3ds file.
I think the secret is in the selection of the photo's. And no refund policy ('the result is as good as your photo').
warewullf ( ) posted Wed, 08 April 2009 at 7:41 AM
Thanks for your reply!
In the past I've tried to use Bryce to make a height-map 3D face from a 2D photo but its never been nearly smooth enough to be useable.
I've done some research on 3D programs but can't seem to find one that would do this. Iv'e found plenty of terrgen-type programs that use heigth maps to make 3D terrain but not one that seems like it would make a decent-looking face.
I don't want to be a pain but can you reccomend one (if you know of any) or point me to a tutorial?
Hoofdcommissaris ( ) posted Wed, 08 April 2009 at 8:04 AM
I do not have relevant experience in this field, but a Google Search for '2d to 3d photo' brings up some good looking links like this: http://www.download32.com/t3d---2d-to-3d-converter-d19457.html
I think some adequate blurring might be needed to get good base material for  a height map.
But for now my Googling is as good as yours. Good luck!
CaptainJack1 ( ) posted Wed, 08 April 2009 at 8:18 AM
A lot of software that does this kind of thing uses two images, taken at slightly different angles.
Since they're only using one picture, I'd guess that they're making a shadow map, too. The technique there would be to find the edges, identify pixels on either side of edge lines that are similar in hue but where they're much darker on one side. This would distinguish shadows from, say, highlights in the hair. approximating the slope of the edge curves at different points and measuring the length of each shadow along a perpendicular to the slope would give some idea of where the light was coming from. I'd be willing to bet that pictures taken in bright sunlight work much better than pictures taken with flat, indoor lighting.
Once you know where the shadows are, you could assume that areas in darker shadow and areas where the shadow is wider recede further back. That would give you a fair approximation of the depth intended in the image.
They might pre-process the image, too. For example, they might have an artist remove the background in Photoshop and adjust the contrast by eye to improve the chances of making a good map, before they run it through their software to convert it.
warewullf ( ) posted Wed, 08 April 2009 at 8:49 AM
Cheers, Hoofd!
You're right, Captain Jack, there is a bit or pre-processing to be done in Photoshop. The figure is usually isolated and placed on a black background then the brightness/contrast is altered to highlight the details.
After that though, you've lost me. I think it might be out of my league....
I've tried to use a heigth/displacement map in 3DSMax but all I get it a raised-but-flat moutain. Like a plateau! Not exactly the desired effect.
Thanks for your help, lads.
pjz99 ( ) posted Wed, 08 April 2009 at 5:06 PM
That site is pretty misleading.  They have a video that purports to demonstrate the process they use, but it's plainly not what they're selling - in the demonstration they have a guy sitting in a studio being laser digitized, they're not working from a photo.  I expect the real process being used is something more like this:
http://lenticularblog.rrd.com/?Tag=Depth+Map
My Freebies
warewullf ( ) posted Thu, 09 April 2009 at 4:00 AM
You're right pjz99. We use a 3D digitzer and the process of making a 3D image that way is easy enough.
Thanks for that link, it makes the 2D to 3D a bit clearer. I'm going to try using 3DSmax again unless anyone can suggest a program better suited to this task?
Simba77 ( ) posted Sat, 21 January 2017 at 11:05 AM
The software used in China to convert 2d images to 3d for crystal engraving is called ShapeMg Official site With the help of it user manual from the link and all its 20 silent tutorials on YouTube you easily get familiar with it. It can also the 3d images to point cloud with is used by the laser printer to create images in the crystal.
d3crypt3d ( ) posted Wed, 25 January 2017 at 8:29 PM
Hey everybody,
BIG NEWS! D3CRYPT3D has been chosen as a finalist for the SXSW 2017 Interactive Innovation Awards! We have been nominated in the category of Privacy & Security. My name is Chloe. Me and my team came up with D3CRYPT3D in response to the growing issue of artists getting their work pirated after spending countless hours and sweat equity into their work. The beta just launched over a week ago and we have been getting some fabulous responses with regards to improvements, features etc. Here is an updated explanation on how the software works. Please check it out :)
Also, check out our feature on 3dprint.com and 3ders.org
https://3dprint.com/153731/d3crypted-software-ip-protection/
http://www.3ders.org/articles/20161102-d3crypt3d-launches-accessible-3d-printable-file-encryption-to-fight-3d-asset-theft.html
Why would I want to use D3CRYPT3D?
You spend countless hours on your 3D creations. These files are sought after and worth real money. Your assets by nature need to change hands after they are created. Our New Build is up and wanted to say thanks to all those who have tried it. I will always post up here when there are changes to this program. Hope this helps you out. This is a more comprehensive explanation of how our program works.
D3CRYPT3D utilizes AES-256 Bit cryptography to fully encrypt the 3D asset itself. During encryption, SHA-2 hashing is utilized to uniquely identify the asset and allow for tracking. Inside the encryption, identifying metrics are stored which allow for full tracking of the asset from the moment it is encrypted. These metrics remain with the .OBJ file after it is unencrypted. The metrics, however, remain in an encrypted form.
D3CRYPT3D differs from Winzip and 7-zip in several ways:
  1. There is no compression algorithm applied
  2. The file type remains the same and can be opened in its native application, even in an encrypted state.
  3. Asset tracking metrics are embedded in the encryption which allows for tracking throughout the lifecycle of the file.
  4. The assets owner is identified by the calling card which gives the artist the ability to promote themselves and control their creations. When someone attempts to open the file, they are directed to the artist to contact them and request the access key.
D3CRYPT3D allows you share your assets with authorized parties and gives you recourse should an asset become pirated or leaked.
The purpose of the beta is to get feedback on vulnerabilities and suggestions on enhancements and feature additions.
The first iteration of the software we release will initially be able to track down the source of a leak. The leak, however, will not be prevented.
In our second iteration of the software, we plan to integrate with several 3D software programs as a plugin and control permissions on the files from inside the programs. In addition, we will introduce a multilayered encryption which is highly enhanced and requires information from multiple separate cloud-based servers in order to properly unencrypt the file.
Without the plugin, you will not be able to unencrypt the file. After the file is unencrypted, what you can and can’t do with the file will be controlled based on the permissions granted by the owner.
Down the line, we will introduce an encryption layer which will allow the file to remain in an encrypted state perpetually from the moment it is encrypted. This layer can then be integrated into gaming engines and 3D printers preventing the ripping of meshes from games while the assets are in play and preventing printing of unauthorized objects. If a person attempts to rip an asset, the resulting meshes will be unusable encrypted data. We realize this is a never-ending battle. Our solutions will be defeated every so often, but our talented programmers will quickly patch the software vulnerabilities further enhancing the product.
Our cloud-based asset tracking and encryption will enable both artists and major corporate 3D asset holders to gain full transparency into the usage, dissemination, and proliferation of their assets in a managed and controlled fashion allowing them to maximize profits and snuff out piracy.
Our team has a deep and thorough knowledge of how data is stored and managed in Windows, Mac, and Pure Linux-based platforms such that we are able to architect systems and file structures in a manner which utilizes every functional aspect of a segment of data stored on a drive regardless of what platform the system is running. We are not complicit with any government body. We champion protecting our user's data and strive to create an environment where the creator of an asset is in full control of their digital 3D assets.
D3CRYPT3D is by the artist, for the artist, and will always choose the artist first. We need your support and feedback to help us in the endeavor of protecting 3D assets worldwide. Too much genius work is being stolen and will continue to be without this intellectual property protection. It’s time for D3CRYTP3D to protect our hard earned creations. D3CRYPT3D. Protecting your ideas one polygon at a time.
FEATURES  a. Strong Multi-Layered Encryption: Protect your valuable 3D assets from piracy i. Prevents unauthorized access to your assets ii. Protects against piracy iii. The file type remains the same and can be opened in its native application, even in an encrypted state. iv. AES-256 Bit Encryption b. Asset Tracking and Control: Know where your assets are and control access to them i. Asset tracking metrics are embedded in the encryption which allows for tracking throughout the lifecycle of the file. ii. Monitor who is accessing your asset c. Calling Card: Sign your 3D creations and drive access requests directly to you. i. Displays your contact information when unauthorized parties attempt to access your file ii. Promotes your work and control your creations
How It Works
  1. Download and Install D3CRYPT3D- Installing D3CRYPT3D is as easy as downloading the app and installing in on your computer. It doesn’t require any configuration or maintenance. The software automatically checks for updates each time you run it ensuring you always have the latest version.
  2. Register- Once you have installed the software, register using a valid email address and create a password. You are now ready to begin encrypting and tracking your assets!
3.Begin Encrypting Files and Tracking Your Assets- Encrypting your files is as easy as dragging and dropping them into the D3CRYPT3D application and clicking the encrypt button! You can drag entire folders of files or one file at a time. Once you have encrypted your file, tracking and protection are now enabled.   Here is the link to download the software- http://d3crypt3d.net/ (click "TRY D3CRYPT3D NOW" on the home page)
Check out our feature with Stranger Things lead concept artists, Nuttavut- http://d3crypt3d.net/2016/10/11/strangerthingsinterview/   Thanks!
LuxXeon ( ) posted Fri, 27 January 2017 at 2:56 PM
d3crypt3d, while the announcement of your 3d encryption software is relevant to the forum, it has little or no relevance to this thread. I will not delete your post, but please consider posting announcements like this either on its own thread, or within one with significant relevance. Much appreciated.
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook: https://www.facebook.com/luxxeon
