Sun, Feb 9, 3:08 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 09 1:04 pm)
Subject: Need Help with Render.
lplp1 ( ) posted Mon, 09 July 2001 at 1:09 PM · edited Sun, 09 February 2025 at 2:20 PM
Please tell me once again what causes this. I am using the V2Map3MaturalHi texture. Thanks
CarolineG ( ) posted Mon, 09 July 2001 at 1:30 PM
It looks like the bum needs to be converted..... Caro
lplp1 ( ) posted Mon, 09 July 2001 at 1:32 PM
One additional note. When I uncheck "Use bump maps" in render options, there is no problem. Is there a way to adjust setting and still use bump maps?
CarolineG ( ) posted Mon, 09 July 2001 at 1:35 PM
that is because the bum needs to be converted first I think, after that it will look ok. Caro
lplp1 ( ) posted Mon, 09 July 2001 at 1:36 PM
Normally poser automatically converts the bump. How do I manually convert the bump. It show up in Surface Materials as "V2HeadBumpHi & V2BodyBumpHi".
CarolineG ( ) posted Mon, 09 July 2001 at 1:39 PM
You go in the material editor and look for the files in the directory where the v2 textures are and select the one that has the same name, after that you will be asked if you want to convert them to bum files, just say yes and after that the dirty look will dissapear.... Caro
lplp1 ( ) posted Mon, 09 July 2001 at 1:48 PM
Ok, It worked. For some reason the "V2HeadBumpHi & V2BodyBumpHi" were in Surface Materials but not converted. When I reloaded them, Poser then ask to convert them. Thanks for the help from all of you.
CarolineG ( ) posted Mon, 09 July 2001 at 1:51 PM
Glad it is working S Caro
Staby ( ) posted Mon, 09 July 2001 at 2:43 PM
I had the same problem when I had just purchased Vicky 2.0 and her Hi res Texture maps. Basically The mat pose files that come with Vicky 2 are the mat files for Pro Pack users. Pro Pack can use Jpg files as bump map without the need to convert them. Even if you have converted the .Jpg Bump Maps In .Bum format every time you use those mat files you get that problem. You need to go to DAZ web site on the V2 texture maps product page and download the update that will install the mat files for Poser4 user that will search for the .bum maps. Hope that this will help :) Staby
visualkinetics ( ) posted Mon, 09 July 2001 at 4:14 PM
Although it does kind of look like a cool texture for an out of use cybog lady! :)
melanie ( ) posted Mon, 09 July 2001 at 8:18 PM
Make sure you're using the maps for P4, not ProPack (assuming you're not using ProPack). I did the same thing, and it turned out I was using the wrong maps. She looked like she had been playing in the chimney. There are really only two maps that work in standard Poser 4 (non-ProPack). Melanie
Norbert ( ) posted Tue, 10 July 2001 at 5:23 AM
With some ratty looking clothes on, she would make a great 'bag lady'. Isn't there a shopping cart in the freestuff section?
melanie ( ) posted Tue, 10 July 2001 at 7:43 AM
There's a shopping cart at Lannie's site. The link should be in the links here. Melanie
