Fri, Jan 10, 6:33 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Aaaaarrrrrggggghhhhh - Vicki Eyebrows
jarm ( ) posted Mon, 09 July 2001 at 1:21 PM ยท edited Mon, 23 December 2024 at 5:44 AM
Hi all I have been fighting this for hours and I cannot get these bloody eyebrows to stop looking like something off a Barbie doll. Does anybody have the definitive settings for Vicki 2's eyebrows? I'm screaming fits of frustration :-) Best wishes and thanks for any help Jody
sinixyl ( ) posted Mon, 09 July 2001 at 2:11 PM
Attached Link: http://www.awakemm.com/poserarcana/tutorials/cp/cp02/
Found this tutorial previously and save it. I dont have Vicky so can't tell you if it can help. But here's a quote from the description . "MAT Pose files allow you to apply color to your model by applying a Pose. Starting with the UpDo Hair model, DAZ started using MAT files and we show you how you can use them to re-colorize eyes, lips, and skin tone singly or in combination. In addition, we show you how to use them to correctly set the transparency state of Victoria 2's eyebrows." It's at the link above hope it help's.
Eowyn ( ) posted Mon, 09 July 2001 at 2:14 PM
I suggest you do a search on Vicki eyebrows here in the Poser forum - this question has been asked over and over again :-)
jnmoore ( ) posted Mon, 09 July 2001 at 2:16 PM
Look in the parameters for her head -- there's a setting for "eyebrows gone". Set it to 1.000. Then, in the materials listing, set the eyebrow color to the same color the rest of her facial skin is set to (also, make sure that is set up to use the face texture). This will allow the eyebrows that are "painted on" in the face texture to show up. Jim
BAM ( ) posted Mon, 09 July 2001 at 2:24 PM
Jody, Please go to Search (below)and type in eyebrows. You will find many references to this problem and the "fix".
BAM ( ) posted Mon, 09 July 2001 at 2:25 PM
Jeez, I get distracted by the phone and someone else steals my thunder.
jarm ( ) posted Mon, 09 July 2001 at 2:36 PM
Thanks dude
melanie ( ) posted Mon, 09 July 2001 at 8:14 PM
I had this same problem and it drove me crazy. All you have to do is make sure that you set transparency ONLY on the UPPER eyebrow, not on the base eyebrow. This fixed it for me. I had inadvertently set trasnparency on both upper and base eyebrows, and what it's basically doing is making an eyebrow-shaped hole in her head. What you're seeing is the black void inside her head. Give this a try and see if it works for you. Melanie
