Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 9:02 am)
I know this isn't the answer you're looking for, but, sometimes, the only thing that works for me is ALT-F4. Which forces Poser to close. :(
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
Quote - Count me in on wanting to know this! I seriously don't like having to close poser when it hangs like that...'specially as I'm always forgetting to save my work...sigh
Me, too. And it only screws up when I've done something that looks COMPLETELY awesome...and haven't saved.
into a fruit salad.
The ESC key works normally, but when Poser is completely frozen,
it doesn't work any better than the Cancel button. There isn't a magic
unfreeze key!
My python page
My ShareCG freebies
In Poser 5 the only way to cancel a render is CTRL ALT DEL and close Poser.
In later versions IE: Poser 6, cancel does work. However, the time it takes to cancel depends on your bucket size. Before the render will cancel, Poser will finish the current bucket that it's working on. If you have a high number for your bucket size, then Poser will continue to process that bucket amount until it's done, and then cancel the render. If you have a smaller bucket size, the time to cancel the render will be less, but obviously the time to render the image will be longer.
say." - Ghandi
That's true. I usually render with a bucket size of 8. I could probably go lower, but why?
into a fruit salad.
Here's a little script that saves the current document then renders.
The script is very simple; the key to making it work is to substitute
the script for Ctrl-R so it's the first thing you hit. (Thus forcing you
to autosave without thinking about it.)
The script:
import poser
poser.SaveDocument()
poser.Scene().Render()
The trick:
Save the script into the runtimepythonposerScriptsScriptsMenu folder,
under this exact name:
SaveAndRender###Ctrl+R.py
And then find the Poser.XRC file, back it up somewhere else,
and delete line 743, which assigns Ctrl-R to the usual render.
Line 743 looks like this:
Ctrl+R
My python page
My ShareCG freebies
Note: the script will work in any version, but the hotkey assignment trick
only works in P7 SR3. (I don't know if Pro is the same.)
My python page
My ShareCG freebies
If you tick 'Separate process' in your render Preferences, you can go into the Task Manager (Activity Monitor in OS X) and 'End Task' ('Force Quit') on the FFRender process without stopping Poser.
In Poser Pro, Render in Background also uses a separate process, whether or not you have the option ticked in Preferences.
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
Quote - Here's a little script that saves the current document then renders.
to autosave without thinking about it.)The script:
import poser
poser.Scene().Render()The trick:
under this exact name:SaveAndRender###Ctrl+R.py
Ctrl+R
Thanks for that :)
I always do save my images before rendering, but a script that will save mouse clicks is always welcome.
Of that script above, do I just save up to "The Trick" or do I save all of it down to the "accel>" portion?
say." - Ghandi
Acadia - the script is just those 3 lines.
On a Mac, the file is called PoserMac.xrc. It's in the main Runtime/ui folder.
It works fine in Poser Pro too.
Note that it only works for a saved document. If it's a new 'Untitled' document, it gives a script error.
what I should be."
Murakami)
I had exactly the same problem a few days ago, MadameX, except it was after a render crash.
First of all, make sure that your original Poser.xrc file is named correctly (you saved the original version under another name, right?)
If that does not fix it, then try a re-install of the latest SR for your version of Poser. Just install it over the top of your current Poser program, and keep your current preferences. Nothing in your Poser Runtime will be deleted.
If you have Poser Pro, make sure to install the separate Queue Manager SR1 update as well.
what I should be."
Murakami)
Thank you for your reply.
But I uninstalled and reinstalled Poser, also reinstalling the SR3 as well. Unfortunately, it didn't work. It installed with my registration # and everything, just as if it hadn't been removed at all. When I opened it, it did the same thing. I'm devastated. I love my Poser. This is ver. 7, btw.
I don't know what to do! I have DAZ Studio, but can't get it to run on my new pc, for some reason. But Poser does...or did.
:crying:
An uninstall may not delete your preference files, which are stored in your user profile somewhere. There is information on the Smith Micro web site, somewhere under Support I think, about deleting your preference files (or renaming the folder). That might be worth a try.
Don't cry... it will be okay!
what I should be."
Murakami)
Well, I found out how to delete the preferences and all, but the location the instructions sent me to only had the Library prefs xml. I copied that to my desktop, just in case, and deleted it. Started Poser again, but no luck. It still will not open. I noticed that the windows dialogue box had a button for more details on this, so I opened it and copied what was there. But have no clue what is happening and not sure if anyone here would either, but here is what it had:
Problem signature:
Problem Event Name: BEX
Application Name: Poser.exe
Application Version: 7.0.4.220
Application Timestamp: 486c3039
Fault Module Name: StackHash_db6c
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Offset: 0012efc4
Exception Code: c000001e
Exception Data: badc0de1
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
Additional Information 1: db6c
Additional Information 2: 4e5d5dc6aabf76cc679d707f73217047
Additional Information 3: b51e
Additional Information 4: c3f4f21ff0efa95302412e4fece51da2
So sometimes when I'm creating, I run quite a few renders to check on my textures/mesh to see my progress. More often than not, I hit render, and Poser freezes some....then when it comes back, I hit cancel on the render about 20 times and it just doesn't take. So I end up waiting 10 minutes until it'll let me.
My quesiton is, has anyone discovered a keyboard shortcut to 'Cancel' a render? Is there a way to stop it without clicking cancel? Just seems it takes sooooo long =)
Thanks in advance
Jackie
Ever stop to think, and forget to start again?
