Mon, Dec 23, 1:43 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 23 1:20 pm)
Subject: Saving Hair textures
3Dpixi ( ) posted Thu, 07 May 2009 at 12:48 AM · edited Mon, 23 December 2024 at 10:14 AM
How can I save my new created MAT pose files for hair into my librarie pose folder?
[I have searched the forum but couldn't find any tutorial]
JenX ( ) posted Thu, 07 May 2009 at 9:07 AM
Which version of Poser are you using, Pearl3D?  You can make a .mt6 file in the Material room, and save it that way, then convert it to a .pz2 file using a text editor and changing a couple lines.
replace
mtlCollection
with
figure
and you should be fine.  You CAN change the "Version number" to 4.01, but that's not necessary, unless you want complete backward compatibility.  Then, save the MAT pose to the Pose folder in your own folder.
or, if your hair is a hair Prop, change
mtlCollection
to
prop figureHair
That should work :)
3Dpixi ( ) posted Thu, 07 May 2009 at 4:11 PM
Thanks for your reply Jenx ...
I am using Poser 7 and I gess you mean it's the same idea as adding MAT pose clothing textures??
Accept for it's a hair prop I need to change the same line but different words ...
Okay ... I will try that ...
Thanks for your advice and willing to help me out on this ...
I realy appreciate it and keep you posted if it has results ;o]]
JenX ( ) posted Thu, 07 May 2009 at 4:13 PM
Absolutely :)  If you want to keep it in the Material Room, just save it as a .mt6 collection, and you're set :)  no need to change anything in a text editor.
3Dpixi ( ) posted Thu, 07 May 2009 at 4:16 PM
 Thank you a lot for advice ... I will get back on this tomorrow to say if it has worked out ;o]
JenX ( ) posted Thu, 07 May 2009 at 4:48 PM
👍  look forward to it :)
3Dpixi ( ) posted Fri, 08 May 2009 at 5:09 PM
 Oh yes it works just fine Jen ... Thank you so much ... You realy helped me out!!
I am creating a full pack ... still a little secret ... gigl
But I will keep you in mind when it's finished ...
[if you like it or not ;o]]
Thanks again Jen ... Have a wonderful weekend!!
[mine will be for sure now ;o]]
Greetz,
Peggy
Pearl3D
JenX ( ) posted Fri, 08 May 2009 at 5:09 PM
You're very welcome :)  I'm glad it worked for you :)
