Mon, Nov 25, 11:59 AM CST
Subject: Multi-part props (pp2)
Richabri ( ) posted Fri, 08 May 2009 at 12:36 PM · edited Mon, 25 November 2024 at 9:41 AM
I wonder if anyone knows how to create a multi-part prop that will load all of the elements into Poser at once with a single click but keep each of the props as separate entities that can then be selected, repositioned or deleted if desired?
I just used a lockers prop (pp2) from Daz and it loaded in a group of  lockers but each one had the ability to be separately selected,  moved or deleted so I know it can be done - I just don't know how :) I tried parenting all of the props to a single base and then resaving the base but that did not work.
Any ideas?
  • Rick
wyrwulf ( ) posted Fri, 08 May 2009 at 12:51 PM
In Poser, when you save the prop, you must click "select subset", then check all the props you want included.
Richabri ( ) posted Fri, 08 May 2009 at 1:04 PM
Thanks so much - that did the trick. For as long as I have been creating Poser props I never used that function before :)
Thanks again :)
  • Rick
wyrwulf ( ) posted Fri, 08 May 2009 at 1:07 PM
You're welcome. I haven't used it much either, and had to try it to make sure it worked the way I remembered before I posted.
