Sat, Jan 11, 12:27 PM CST
Subject: Saving Poses
1010 ( ) posted Tue, 10 March 2009 at 4:00 PM · edited Sat, 11 January 2025 at 7:17 AM
Maybe this was asked already but when you want to save a pose, what boxes do we click if any, after we click the add button?
http://creationsbydawn.net
Adom ( ) posted Tue, 10 March 2009 at 4:34 PM
After you click that small + (plus) button first dialog will appear.
OK and CANCEL doesn't need explanation.
SELECT SUBSET - here you can choose which body parts should be saved (instead of whole Figure)
Next window asks about BODY MORPHS (all those additional dials which are not in basic figure) and BODY TRANSFORMATION (if you moved BODY actor and you want to save it, older versions of Poser never saved that)
Last one will be about how many frames to save (if you have more than one)
I hope that is what you asked for:)
1010 ( ) posted Tue, 10 March 2009 at 4:45 PM
I'm using P7 and haven't checked any of those. Won't it also change the morph of another character if I use that same, saved pose on them?
Adom ( ) posted Tue, 10 March 2009 at 4:51 PM
If you didn't check BODY MORPS then none of them will be saved to pose file so it won't affect any morps (even if those are the same) on the other figure (or same figure).
ockham ( ) posted Tue, 10 March 2009 at 5:10 PM
If you don't check those boxes, the Pose will only include rotations
(xrot, yrot, zrot) and translations (xtran, ytran, ztran) on body parts.
So it won't affect morphs on the target figure.
One complicated exception: If the target figure has some ERC coding
that causes its own morphs to be moved by rotations, like muscles
that bulge when the leg bends .... then those morphs will be affected,
because the target figure is setting those morphs in response to the
rotations from the pose.  But the pose won't directly change any morphs
unless you've checked the Morphs box.
My python page
My ShareCG freebies
1010 ( ) posted Tue, 10 March 2009 at 5:15 PM
Thank you for these answers.....
pjz99 ( ) posted Tue, 10 March 2009 at 6:21 PM · edited Tue, 10 March 2009 at 6:25 PM
Be aware that if you're using Poser 7, a ton of extra information that is largely useless will be included in the pose file - a "refActor" block for every bone, plus a lot of other junk.  This is intended to support "Universal Poses", but in practice they aren't particularly universal and won't be interpreted by older versions of Poser or DAZ|Studio anyway.  If you're going to redistribute your poses, you really ought to take that junk out.
Also, as Ockham says, translateX/Y/Z values are recorded into a pose file as well - really the only things that should go into a pose for distribution are joint rotations, except for the hip (translations are OK there).  Extraneous translateX/Y/Z junk ought to be removed.
Oops, one thing more: for V4 and for the EF Sydney/Simon figures, when selecting what actors (body parts) to save a pose for, be certain to exclude the magnets and only get actual body parts.  There is no situation where you'd want to include the magnet positions into a pose file, they're controlled automatically by ERC in various other bones.
My Freebies
1010 ( ) posted Tue, 10 March 2009 at 6:29 PM
You are all so knowledgeable, thank you for all these insights.
pjz99 ( ) posted Tue, 10 March 2009 at 8:16 PM
Something that will take a whole lot of the mystery out is to make a small pose file and just look at it in a text editor for a while - it won't make sense for a while, it's like learning any language.  If you don't know the syntax and the vocabulary, it's all gobbledygook.  This document explains it all in excuciating detail - which also won't make any sense until you learn the language:
http://www.kuroyumes-developmentzone.com/poser/poserfilespec/ucr2filespec_dec2004.pdf
My Freebies
Acadia ( ) posted Wed, 11 March 2009 at 6:48 AM
And if you want to save partial poses, follow the instructions in this thread:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2735288
1010 ( ) posted Wed, 11 March 2009 at 6:03 PM
Thank you Acadia, that was very helpful. I saved a few poses but something strange happened. When I went from one pose to another, the hand poses only did part of the pose I saved. For instance, I had a hand with just the index finger pointing and when I switched to another pose, the hand went way back and not what I saved. What am I doing wrong????
pjz99 ( ) posted Wed, 11 March 2009 at 6:29 PM
If you're using "grasp" dials on a figure like V4, or some other setup that uses a master dial to make all the fingers bend at once, those values won't be included in a pose file (maybe if you include morphs though).
My Freebies
1010 ( ) posted Thu, 12 March 2009 at 8:21 AM
Ok, I will try just bending the fingers one at a time, seems so silly to do that though. Thank you again.
pjz99 ( ) posted Thu, 12 March 2009 at 10:56 AM
Somebody on the DAZ forums has a script that will convert grasp dial values into ordinary finger bend values (search their forum).
My Freebies
1010 ( ) posted Thu, 12 March 2009 at 4:43 PM
Oh that sounds great, thank you again.
ninhalo5 ( ) posted Sat, 09 May 2009 at 8:05 AM
time for another post hijack :)
regarding saving poses, how would you save a pose that will work anywhere on the stage?
example: I create a pose and the figure is at 0,0,0  and I save that pose.
clear the scene and load up my model and place it at -10,0,32.
now when I click on my saved pose the model will jump back to 0,0,0
I've had poses that others made that will work anywhere just click on the pose and it takes effect where ever the model stands.
Also is it possible to do something like this with an animated set?
thanks
nruddock ( ) posted Sat, 09 May 2009 at 8:29 AM
Quote - time for another post hijack :)
Either don't save or edit out the Body XYZ translation channels.
ninhalo5 ( ) posted Sat, 09 May 2009 at 11:28 PM
how do I not save these channels?  would these be changes I make to the pz2 file in my editor?
Thanks
ninhalo5 ( ) posted Wed, 13 May 2009 at 7:33 PM
Ok I went through my pz2 file in a text editor and the body looks to be set at 0 for translations and it works fine in D|S  I can move the character anywhere on the stage and apply the pose and she will pose right where i put her, however poser still moves the character back to where the pose originated. the body translations are 0,0,0 during the pose.
what do I need to do to edit out these translations so the pose will be universal?
thanks
nruddock ( ) posted Thu, 14 May 2009 at 3:15 AM
Quote - Ok I went through my pz2 file in a text editor and the body looks to be set at 0 for translations and it works fine in D|S  I can move the character anywhere on the stage and apply the pose and she will pose right where i put her, however poser still moves the character back to where the pose originated. the body translations are 0,0,0 during the pose.
You need to remove the Body translations.
ninhalo5 ( ) posted Thu, 14 May 2009 at 7:10 AM
Quote - You need to remove the Body translations.
i'm sorry perhaps i'm a tad dense :)
how do I remove the body translations?
do I just delete this part?
actor BODY:1
    channels
        rotateY yrot
            keys
                k  0  0
        rotateX xrot
            keys
                k  0  0
        rotateZ zrot
            keys
                k  0  0
        translateX xtran
            keys
                k  0  0
            trackingScaleMult 1
        translateY ytran
            keys
                k  0  0
            trackingScaleMult 1.000000
        translateZ ztran
            keys
                k  0  0
nruddock ( ) posted Thu, 14 May 2009 at 3:29 PM
Quote - > Quote - You need to remove the Body translations.
actor BODY:1
    channels
Yes.
ninhalo5 ( ) posted Thu, 14 May 2009 at 7:53 PM
great thanks,
I'll give it a try
