I'm using Poser 6. When you talk about increasing the crease angle.... is that something I need to do in Poser? Or are you talking about re-opening it in Wings and doing it in there? In either case, I'm not sure what you mean exactly...
Here's the link to my freebies: https://www.renderosity.com/mod/freestuff/?uid=493127
My cousin Jack can speak to beans. That's right.... Jack and the beans talk
Whoa - adjusting the crease angle just made it worse, but, I unchecked the "smooth polygons" box and that fixed it right up. Shows how much I need to learn about Poser. Thanks!
What you are seeing is the effect of poser smoothing. If the ends of a cylinder are not visible you can simply delete the polygon , otherwise unweld it . The square part of the hammer can be improved by small bevels along the edges, or unwelding .
Changing the crease angle should fix the problem in poser 7 , but you will need to play with the settings , try 30, 45, 60, 80, 120, 160 degrees and see what happens to that mesh . Turn smoothing off is an option too. In some cases you want smoothing on but parts of the model need sharp edges, That is a matter of small bevels and selected unwelds .
Splitting vertices is an unwweld but unwelds everything so may be overkill. Learn to be selective.
Nice BIG hammer by the way .
Hi everyone,
I'm hoping someone can tell me why this happens when I render a piece I'm working on. The unrendered hammer I made looks fine. But when I render it, it shows up all fat and out of shape. Have a look at the pic below for before on the left, and after on the right. Does anyone know why this is?
I created the hammer in Wings 3D, and saved it as a .OBJ file. Once I imported the hammer into Poser, I applied a texture I made and this is how it turned out. So, I tried something else; I turned it into a Poser prop, then deleted the .OBJ. I re-textured the hammer, and got the same result. Does anyone know how I can get it to keep from doing this?
Thanks -
