Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Sep 17 7:30 pm)
I never got that far myself, but I know that some used "switched" JCMs on V3's collars - one morph optimised for the collar up movement, and one for the collar down. Then limits would be forced for each, so that the morphs would swap over at the zero up-down point. If your technique is markedly different I'd be interested to know more.
If you haven't done so already, you may want to check that your JCM linkages survive being saved to the library, and that there is no crosstalk when more than one figure is in the scene.
I'd better not watch your videos while at work, but will do so later. :-)
Can't say that I have heard of it being done with JCM, but with joint controlled joints this type of thing is sometimes done in mechanical figures. I recently did something with JCJ in a set of cameras. It would take too long to explain how it worked in cameras, but is easier to explain in a test I did for it with box props.
One master dial is used raise each box in sequence, whilst keeping the other boxes on the ground. Each box has its ytran limits forced to between 'min 0' and 'max 1', this ensures that no box can move downwards below zero yTran. Each boxes yTran is slaved to a valueParm channel named 'neg1' with a deltaAddDelta of -1, neg 1 has a dial value of 1, this channel is hidden and its value remains unchanged. Each box is also slaved to another valueParm channel named 'master' with a deltaAddDelta of 1, so that it tends to pull all the boxes up as the master dial is incremented.
Box 1 is then slaved to each subsequent boxes yTran with a minus deltaAddDelta value that matches the box number. So box 1 is slaved to box 2 with a deltaAddDelta value of -2, to box 3 deltaAddDelta value of -3, etc. Each box then has the same slaving code, except that it is not slaved to any of the preceding boxes. So box 2 is not slaved to box 1, and box 3 is not slaved to boxes 1 or 2, etc, and box 6 is not slaved to any other boxes.
I got severe brain strain trying to work out how to do this, but got there in the end. I can post the file if anyone is interested.
Quote - If anyone's interested, I'm happy to explain in more detail what I did.
I would be very interested to hear the details.
The result is a neatly spaced pile of slats.
(I think this description is sort of backwards, but trying to parse it out
again would give me a headache.)
My python page
My ShareCG freebies
You guys are way ahead of me (not unexpectedly, of course).
What I did was a generalization of the method EnglishBob described. Or a simpler version of lesbentley's, depending on how you prefer to look at it. I didn't interpolate between the different morphs, just stacked them on top of each other. So in my version of lesbentley's demo, the boxes would just stay up and never go back down.
More specifically: I used three morphs A, B and C for that knee bend, all of them with enforced limits of 0 and 1 and slaved to the shin's x-rotate channel with factors of 0.011111, 0.033333 and 0.033333, respectively. Then I created a channel called 'one' in the BODY actor with a fixed value of 1. I slaved the B morph to that with a factor of -3 and the C morph with -4. So between 0 and 90 degrees, only the A morph is active. From 90 degrees on, A stays frozen at 1 and B reaches its lower limit of 0, so it start becoming effective. Then at 120 degrees, B is at 1 as well and C starts to take effect.
PS: I love those blinds, by the way.
Almost anything is possible along these lines if you have enough
concentration and enough aspirin.
You might also take a look at the "Dependent Parameters" or "Keyframed ERC"
technique, new in P7. It probably wouldn't be any easier for your particular
joint switch, but it opens up a whole range of sequencing operations; basically
capturing any animated pose in a control dial.
My python page
My ShareCG freebies
lesbentley: I thought about your box example some more. I would probably try to reduce the brain strain by decoupling the boxes. You could add a channel "down" to each box that is slaved to the master channel with a factor of -1, clamped at 0 and 1 and with some offset added by slaving it to your constant channel with an appropriate factor. Then slave the ytran to the master channel, the constant channel (this time with a different factor for each box) and the down channel.
The downside is that you would need more additional channels. The upside is that you could make one template box and simply copy that with the factors adjusted appropriately.
I have, and I think it's a great way of dealing with complicated joints. Here's what I currently have for the knee bend of my Antonia figure:
http://www.youtube.com/watch?v=bhq0s47--5U
http://www.youtube.com/watch?v=BBDS30dQxmQ
The idea is to use a series of JCMs instead of just one, each starting to take effect at a different angle. In particular, I would start to model the effect of the shin and calf being pressed onto each other at the correct angle at which this actually happens, but not earlier.
This is probably a well-known technique, but it is new to me, so I thought I'd share. If anyone's interested, I'm happy to explain in more detail what I did.
