Sun, Feb 2, 5:12 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 4:55 pm)
Subject: Looking for stockings/nylons/pantyhose for P4.
LarcenTyler ( ) posted Wed, 20 May 2009 at 7:06 PM · edited Sun, 02 February 2025 at 2:30 PM
A friend of mine has this texture/clothing/whatever, but doesn't know the name of it.  Can anyone help me out? I know it's for the standard model, not for Victoria or anything like that AFAIK.
arbee999 ( ) posted Thu, 21 May 2009 at 9:41 AM
If you're looking for stocking textures for the Poser 4 woman (affectionately known as Posette :biggrin: ), then try here in the Rendo Free Stuff section.
psychosis2000 has a freebie called Stockings Textures for P4 Female that may be just what you're after.
bagginsbill ( ) posted Thu, 21 May 2009 at 11:20 AM
Can't help you find the prop, but FYI you don't need one.
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2719482
These are all done with the shader provided in the linked thread. You apply the shader directly to the legs (and hip). If your figure doesn't have a separate material zone for these areas, you can quickly make one using the Poser Grouping tool. It's all shown in the thread.
EnglishBob ( ) posted Fri, 22 May 2009 at 8:01 AM · edited Fri, 22 May 2009 at 8:03 AM
Attached Link: http://www.morphography.uk.vu/materialassign.html
BB's stocking shader is the business, except that Posette doesn't have separate leg material zones. So unless you want her clothed in an overall body stocking (!) you'll need to define a new material zone for the shader to use.
The link is my ages-old tutorial on how I used to do it. Should still work. ;)
PS: how can you have something and not know its name? Just wondering...
bagginsbill ( ) posted Fri, 22 May 2009 at 9:24 AM
EB:
The 3rd through 5th post in the stocking shader thread is a tutorial on how to make a new material zone, in Poser, without using another tool. Do you think it's better to use UVMapper?
EnglishBob ( ) posted Fri, 22 May 2009 at 9:47 AM
Apologies, I hadn't read the thread for some time, I just use the shader nowadays. Personally I find UVMapper easier to use than Poser's grouping tool, even though it does involve some file hacking. I like file hacking. :)
