Easiest way, at least for me is just cut your object up in your modeling program with the right Poser names, they save the object and point a suitable CR2 at it. If the dress (or whatever) has been fitted over the figure you can use the figure's parts to work out where each part is cut. But- dresses can't have shins, at least shins that are in mesh. While you can put a weld command to weld the joint, you can't make such a dress bend the shins separatly, the other shin isn't in the hiearchy for that shin, so the bending and whatever doesn't work on it. So what you have is a dress that can be sat it, but will only work for poses where both shins move togeather - I would guess you are aware of that, though.
Sorry about not getting the tutorial ready, but I was just put on a new project at work, which is going to take several weeks to complete. It is taking me away from my family longer than I wanted, which doesn't make me very happy. I am not going to have time to explain everything I did on the dresses (which really wasn't much), but basically all I did was bring up the dress is Poser, save it as a .obj file, delete the original from the screen, bring the new .obj file back into poser and used the grouping tool to regroup it...with SHINS, thighs and a hip and sometimes the feet. (I noticed the dresses don't have any shins or feet). Then I brought in the catsuit and replaced the body parts with the new groups. (I had to work with the grouping tool a little (I am no expert) to get the groups aligned correctly (not overlapping)). By the time I ge back, hopefully someone can figure out a better way, because I am no expert. Good Luck See ya in a few weeks. Beos53
PoserPro 2014, Windows 7, AMD FX-6300 6 core, 8 GB ram, Nvidia GeForce GTX 750 Ti
