Tue, Feb 25, 1:00 PM CST
Forum Moderators: RedPhantom
Subject: Rflection maps with Poser 4 render option
wtsmith ( ) posted Mon, 25 May 2009 at 4:05 PM · edited Tue, 25 February 2025 at 10:49 AM
I use Poser 4 render option when rendering out animations.
I'm trying to use the Poser4 reflection maps for metal.
A long time ago when using Poser4 Pro Pak they worked great.
Is there a tutorial or can some one go through the steps to make
the reflection maps work .
I'm using Poser 5 and Poser 7.
But want to render out in Poser4 render mode.
Thanks for any feed back on this
Bill
Anthanasius ( ) posted Mon, 25 May 2009 at 4:34 PM
Hi
You can create an image of your environment with yhe genibl from BB http://sites.google.com/site/bagginsbill/free-stuff/genibl---ibl-generator, after you transform it to a reflexion map with hdrshop, menu Image-Panorama-Panoramic transformation-input : probe - Output : Long/Lat ...
After you plug the "deplied" map to your reflexion node ...
Génération mobiles Le Forum / Le Site
lmckenzie ( ) posted Tue, 26 May 2009 at 2:24 AM
Load reflection map in Reflection Map :-)
Object Color: Black
Highlight Color: White
Ambient Color: Black
Reflective Color: White
Check Multiply through lights
Uncheck Multiply through object color
Reflection Strenth 90-100
I think that should work for a start if I'm recalling Traveler's old tutorial correctly.
