Thu, Jan 23, 4:27 AM CST
Subject: OT: Help needed from the computer gurus, or anyone else who might know what's wr
RedPhantom ( ) posted Tue, 02 June 2009 at 9:28 PM · edited Wed, 08 January 2025 at 8:22 AM
Site Admin
When I put a CD or DVD in the drive sometimes the computer restarts.
*It is inconsistent when it happens.
*It has done it with disks I have burned, both single write and re-write ones, and with store bought disks, even blank disks.
*It will do it if there is a disk in the drive when I try booting up the computer in the morning and when the computer has been on for a while.
*Most of the time it happens when I put a disk in, but has happened after 5 minutes or more, but when I'm accessing the disk.
*It doesn't always do it to the same disks. The same disk might not work today but will work tomorrow.
This I have tried:
1.      Installing a new drive
2.      Reinstalling Windows (I have XP and the latest service pack)
3.      Changing the battery (it’s a desktop. I’m referring to the little round one inside. It was dead)
4.      Scanned for viruses
5.      Changed the port the drive was plugged into
6.      Swearing, begging and bribing
Does anyone have any other suggestions? I’m at my wits end.
Thanks
Dave-So ( ) posted Tue, 02 June 2009 at 9:56 PM · edited Tue, 02 June 2009 at 9:58 PM
power supply
you may be getting a voltage drop with the CD...
OR heat...is everythin clean inside..the CPU fan working...clean heatsink and all that?
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
dphoadley ( ) posted Tue, 02 June 2009 at 10:23 PM
Have you tried the repair solution that the Russian in Armageddon used?  -bashing it with a spanner?
DPH
Dave-So ( ) posted Tue, 02 June 2009 at 10:32 PM
BFH sometimes helps too
markschum ( ) posted Tue, 02 June 2009 at 10:35 PM · edited Tue, 02 June 2009 at 10:37 PM
In control panel off the start menu is administration tools, Check the event log and see if the system caught anything.  I like the suggestion on the power supply fault.  It may also be a drive error if the cd drive is the same address as your boot drive. AS soon as your cd starts your boot drive goes offline . Check your drive numbers
bantha ( ) posted Wed, 03 June 2009 at 9:08 AM
Seriously, sounds like the power supply to me. May be a faulty cable too.
-"Amazing Grace" Hopper
pakled ( ) posted Wed, 03 June 2009 at 12:05 PM
yeah...I'd go with the Power supply. Possibly it's shorting the system when accessed. The 'little battery' is for your settings (date, time, BIOS changes) to those who don't know. They go usually in a coupla years...
Acadia ( ) posted Wed, 03 June 2009 at 4:52 PM
Without having read the above replies, my first thought was "over heating."  My old computer used to do that.
Half-Baked ( ) posted Wed, 03 June 2009 at 5:19 PM
It could be power supply linked to overheating. They run less efficiently the hotter they become.
sixus1 ( ) posted Wed, 03 June 2009 at 5:26 PM
I too would go with checking the power supply.  Seems like they just don't last like they used to anymore.
Oh yeah, and be SUPER careful when you change it out....I had a loose connection last time I did it and fried my video card in the process...there was electricity popping and smoke...the whole shebang.
geoegress ( ) posted Wed, 03 June 2009 at 5:43 PM
I had the same thing-- power supply - you need a new one.
hborre ( ) posted Wed, 03 June 2009 at 6:08 PM
For troubleshooting, I would agree with the other posts.  If you have spare parts. start swapping them out one at a time and see if the problem persist.  Start with the CD/DVD just in case the unit is malfunctioning.  Next borrow a power supply from someone and swap that.
In most case, fan failure will be detected by the motherboard and you will not be allowed to boot beyond your bios.  As a last resort, check your RAM.  I had an issue with one computer where it would shut down without warning and in order to reboot, I had to unplug and replug the power supply.  After changing video card, fans,  power supply from spare parts and eventually resurrecting a spare motherboard into a new case, did I find out that 1 DDR chip had gone bad.  That took me a better part of a year to figure out.
RedPhantom ( ) posted Wed, 03 June 2009 at 6:52 PM
Site Admin
Thanks. I'll check it out. I may have a spare power supply around. Or I can barrow the one from my son's computer. It's similar to mine.
