Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
That has always been a problem with no easy solution. IIRC, there might be a script to make those isolated changes over selected object parts. Currently, I use bagginsbill's VSSProp to enhance the skin textures of all my models. The convenience, one change will carry over to all associated body parts. Very easy to use once you get over the small learning curve, and you won't deal with unnecessary skin tinting unless you desire it. Search the forum for VSS. It is a shader system that make a world of difference.
Face-off did a script 2 years ago for V4 but it works on M4 as well. Here it is (get rid of the txt extension).
But there is a mat-pose file that loads a shader. This shader has a blue tint in the Diffuse_Color. The purpose is to remove some of the overall baked-in red of the color map, and then add red back selectively based on the lighting so as to make some semblance of sub-surface scattering in the skin. The redness is added using a Color_Ramp node driven by a Diffuse node to measure the amount of light hitting the surface.
This technique was introduced by me and then later discredited by me. But Daz has been using it ever since.
It works for many lighting situations, but not all, and the shader totally blows up if you're rendering with Poser Pro gamma correction turned on.
However, it isn't always blue - and sometimes it is too red. So it all depends on your lighting.
Since then, I've come up with better ways to render skin.
Here is a comparison, with my default lights, not Poser's default.
Left is plain no-shader M4. Middle is M4 with his Daz supplied shaders. Right is M4 with my free VSS shaders.
Which one do you think you should be using?
There is a bug with Poser Pro's (And maybe Poser 7's, too) P4 renderer.
After you open Poser and load your figure, render ONCE with Firefly and RAYTRACING in the MANUAL settings enabled.
You don't have to let the render finish, but it will unlock the P4 renderer's ability to render shaders correctly.
Except for effects based on actual raytracing, the "new" P4 render engine is as good as Firefly (and FASTER) in correctly displaying shaders.
But you first have to give it a poke by rendering once with FF.
Otherwise it will behave like the "old" P4 renderer and just tint M4's skin blue.
It will also render diffuse colors way darker than shown in the preview.
Again, this behaviour is gone once it is "unlocked" by a raytraced render.
If you close the scene and start a new one, you have to unlock the P4 renderer again.
If you open a saved "unlocked" scene fom a pz3 file, the P4 renderer stays unlocked.
JoePublic - this is new to me. Thanks for the post. I never use the P4 renderer so I never ran into this. Nor have I read this posted before.
Quote - JoePublic - this is new to me. Thanks for the post. I never use the P4 renderer so I never ran into this. Nor have I read this posted before.
but i remember months ago you showed someone how raytracing is important for AO and shadows and you made an example with P4 render . and it looked normal.
I may test P4R occasionally because someone asks a question, but I don't fire it up and investigate it on my own, the way I do every little detail of Firefly.
