I usually stick with the adaptive bucket size, but I haven't done a "serious" render* for ages, so hopefully one of the experts will chime in with some advice. In general, upping the bucket size will make the render go faster, up to the point where it runs out of memory... Whether your renderer can take advantage of all those gigabytes depends, I think, on your Poser version and your operating system.
(*In other words, for artistic purposes, rather than checking that something I made works properly.)
since you have 6 gb ram you either have a 64 bit Operating system or ... In Poser Pro I believe one of the render options( external render? ) uses the 64 bit renderer. I would start doubling up bucket size until you see high memory useage. Say 256 to start. Use multiplre threads as well.
Use the same scene to render , something with a few hair would be good.
I had the blank render problem, when I had my preference setting to "separate process".
It would render in preview, but not in Firefly.
But, this would happen only with props. Once I added a Figure to the scene, then the prop would render.
It was very weird.
I ended up unticking the 'separate process' check box and firefly would render away.
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
Hello everytime I try to render on manual settings the render (still takes ages) but comes out blank.
Anyone else have these problems ... am I doing anything wrong?
Rendering on Auto is fine.
