Sun, Feb 16, 6:16 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Carrara Free Stuff here.
Subject: Production Frame Question
jt411 ( ) posted Thu, 18 June 2009 at 3:41 PM · edited Sat, 08 February 2025 at 12:47 AM
Hi guys,
Sorry if this has been covered before, but I'm having an issue with the visible production frame in C7. I use a 22" monitor on one of my machines with the screen resolution set to 1680X1050; when I set my output dimensions to a "portrait" ratio (like 8"x10") the top and bottom of the production frame disappear, like the frame is too big for my monitor. Is there any way to adjust this?
Thanks,
JT
benney ( ) posted Thu, 18 June 2009 at 4:06 PM
Just select the division line between you 3d view and general and then basicaly drag it in to make the view narrower and you will find that this will rectify the problem... I have the same issue with my wide screen
jt411 ( ) posted Thu, 18 June 2009 at 4:16 PM
That worked! Thanks benney!
benney ( ) posted Thu, 18 June 2009 at 4:19 PM
no problem... glad to be of help
MarkBremmer ( ) posted Thu, 18 June 2009 at 4:24 PM
 The other trick is to use the magnifying glass to back out of the image a little and then again use the magnifying glass to draw around the production frame to view it correctly. I prefer this method because it doesn't actually change the "lens" of the camera for rendering.
