Sat, Jan 11, 3:23 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Python script that will remove a folder structure within Runtime...?
DarkEdge ( ) posted Thu, 18 June 2009 at 7:54 PM · edited Mon, 23 December 2024 at 11:46 AM
Is it possible to have a python script that would remove any and all files within a Runtime folder structure?
Like anything withing DarkEdge:Simon:ThisFile
Thanks
nruddock ( ) posted Thu, 18 June 2009 at 8:34 PM
Quote - Is it possible to have a python script that would remove any and all files within a Runtime folder structure?
Is there a particular reason why you want a script for this ?
As it seems likely that you'd have to browse to the directory you cleared, why not just delete it via Explorer.
If you just want to be able to delete a directory tree by specifying a (full or relative to some location) path, then a simple BAT file would seem more appropriate.
DarkEdge ( ) posted Thu, 18 June 2009 at 8:45 PM
Okay, sounds great.
I have no idea what you are talking about.
Can you assist me further?
markschum ( ) posted Thu, 18 June 2009 at 10:31 PM
Yes it is possible using python. If you can specify exactly what gets deleted.
The python command is a combination of walk , which lists a directory tree but you have to do deletes from the bottom up if you are deleting folders too. Its also not something you can get wrong , a mistake is very very bad .
If its just files though you can also do that from the cmd prompt using the old commands like dir  and kill.
DarkEdge ( ) posted Thu, 18 June 2009 at 10:41 PM
Well, I wanted to delete some files within the Runtime structure, they would be specifically within my own folders within that structure though. Understand?
Could that be done without botching the rest of the Runtime folders/files?
Example: Runtime:Geometries:DarkEdge:Simon:ThisFolder:ThisFile.obj
markschum ( ) posted Fri, 19 June 2009 at 1:35 AM
If you wanted to delete all contents of say "Simon" folder  and everything below it in the tree that can be done by script. It would be almost as fast to use windows explorer and do it manually unless you need to do it very often , like a test installation.
The script would need to specify an exact file or folder name to delete .
adp001 ( ) posted Fri, 19 June 2009 at 6:31 AM
Sorry, no. You need just:
import os
os.removedirs()**
This will delete the path and files/subdirectories in the path.
