Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 27 7:02 pm)
Unparent and unpoint, pretty much the same answer. On the menu, hit
Object : Set Parent, or Object : Point At, and then select UNIVERSE as the target.
Ghosting is harder. Poser's transparency isn't really satisfactory for this.
If you search for previous threads about "ghost", you'll find several tricks in postwork,
basically rendering the figure and the background separately and then using
Photoshop layers to get the right combination of color and transparency.
My python page
My ShareCG freebies
As you can see from the image it works very well and the best thing about it is that it gets rid of the body parts that are not up front. If you use transparency and trancelucency you may run into that problem where you see more then you bargained for.
Food for thought.....
aeilkema, Thank you so much. Great price $2.50. The only thing that concerns me is that there is a mention of a "core" something. Which I was able to get as well. I'm just trying to figure out if this is for use only for P7 or is it compatiable with P6. Is this "core" thing only for P7?
R I P MJ. He's must have needed an Angel escort in
Farrah
Please spay and neuter your pets. Strongly consider shelter
adoption before spending $500 to $1000. If you MUST part with that
kind of money for a pet, go to your local shelter, donate the money
to them and pickup a highly adoptable pet. The shelters could sure
use the donation.
Attached Link: http://www.runtimedna.com/Utilities-Core-1.5.html
Core comes with both P6 and P7 versions of the script.Thanx all! Once again I found what I needed here at the forums. Made this purchase. Will play with it tomorrow.
Farrah
use the donation.
Sorry, forgot about the core indeed, but I see it was sorted out already. Have fun playing with it! I don't use it very often, when when I do it gives great results in no time at all.
Greetings and Salutations,
to point at anything.
Using P6 V4 and WinXp
Many Thanks In Advance,
Viper
RIP MJ I guess he needed an angel escort to heaven in Farrah Fawcett
R I P MJ. He's must have needed an Angel escort in Farrah
Please spay and neuter your pets. Strongly consider shelter adoption before spending $500 to $1000. If you MUST part with that kind of money for a pet, go to your local shelter, donate the money to them and pickup a highly adoptable pet. The shelters could sure use the donation.
