If you are using the original "Victoria 4.2.cr2" that came from the V4 install, try running the "Update Victoria 4.2 Base" link that should have been installed on your desktop when you installed V4. I think that will probably solve the problem. The "Update Victoria 4.2 Base" should be run after you install any morph packs.
If you are using a copy of the "Victoria 4.2.cr2" that you saved before installing the ++morphs and running the "Update Victoria 4.2 Base", or can't find the updater for some reason, try using the free "Poser Python-Morph&FBM_Pose". That Python script will save a pose that includes settings for morph and Full Body Morph (FBM) dials, and nothing else.
You're a wizard, Mr Les Bentley, and a valuable asset to our community! Thanks for that gift!
Quote - You're a wizard, Mr Les Bentley, and a valuable asset to our community! Thanks for that gift!
Actually, most of the credit for those py scripts should go to svdl. All the scripts are very slight modifications of a script that svdl wrote, and I would not have had a clue how to write them from scratch.
Any way, I'm glad that the scripts seem to be proving useful. I have plans to post one or two more.
Hi
I have a problem with saving my V4 morphed face in my library.
It is a combination of base and ++morphs and if I press the plus symbol in the pose section of my library it only saves the base morphs in the pose-file not the ++morphs.
Any ideas?
Thanks!
