Sat, Feb 1, 10:06 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 9:18 am)
Subject: possible to get another color out of the Hair Node?
MistyLaraCarrara ( ) posted Wed, 15 July 2009 at 2:00 PM · edited Tue, 14 January 2025 at 1:55 PM
typical default Hair node setup.
I was wondering if it would possible to sprinkle in a few blue hair strands in the one hair wisp group,
or do I have to create another group?
Thanks.
markschum ( ) posted Wed, 15 July 2009 at 2:23 PM
The root and tip colors are both inputs , so you can use another node or map to feed in a root or tip color.
JoEtzold ( ) posted Thu, 16 July 2009 at 1:22 PM
You might try it with some u-v-mathematics like in the second left iroquese in my gallery image.
But this is a trial and error game cause it seem that the u-v-coordinates are following the scalp cap and not the hair as such.
And you can combine the hair node with other, e.g. the HSV node. By a tip of Dimension3D I pushed the Hair node to the hue channel, anyway its the second channel of hsv, and set color to full red (255,0,0 RGB). This will make nice colorful effects, as seen in my gallery image.
But one shouldn't forget that the hair node is a lighting node, so the color effects are subject to change with changing of the main lights and their directions.
But for some specific colored streaks in the hair, I guess, you'r right. There must be given hair groups.
dadt ( ) posted Fri, 17 July 2009 at 7:20 AM
You don't need separate groups to get streaks of colour in the hair like this.
dadt ( ) posted Fri, 17 July 2009 at 7:27 AM
The tip colour is set by a texture map using the skullcap UV map as a basis,
dadt ( ) posted Fri, 17 July 2009 at 7:29 AM
The effect can be increased
dadt ( ) posted Fri, 17 July 2009 at 7:31 AM
By driving the specular colour with a similar map
MistyLaraCarrara ( ) posted Fri, 17 July 2009 at 9:24 AM
thanks dadt,
that's what I was hoping for.
