Sat, Feb 8, 6:03 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 8:53 pm)
Subject: exploding head syndrome in the Cloth room. why does this happen?
MistyLaraCarrara ( ) posted Tue, 28 July 2009 at 1:42 PM · edited Sat, 01 February 2025 at 3:57 PM
this is the 3rd calculation I'm running for the dynamic skirt.   The only thing I changed this time was the "stretch resistance".
Canceling the draping doesn't stop the explosion.
Even changing back to the Pose room doesn't stop the geometry from exploding into infinity.  A few seconds later, total app crash.
The same thing happened a couple days ago, it was her hand that exploded.
bantha ( ) posted Tue, 28 July 2009 at 1:56 PM
I did not have it that drastic. When I had exploding polys in a cloth sim, it were always intersections with the model before the simulation starts. May that be the case here too?
-"Amazing Grace" Hopper
pjz99 ( ) posted Tue, 28 July 2009 at 2:41 PM
What exactly is going crazy?  Looking at your pic I'm not even sure the problem is with any dynamic cloth (which would seem to be the skirt, in your scene).
My Freebies
MistyLaraCarrara ( ) posted Tue, 28 July 2009 at 3:17 PM
> Quote - I did not have it that drastic. When I had exploding polys in a cloth sim, it were always intersections with the model before the simulation starts. May that be the case here too?
Maybe the first 2 simulations didn't totally clear?
When I first did the dynamic simulation, before saving the skirt to the library,
I posed her in frame 20.
This time the pose is in frame 1.
The top menu has the thing to re-do all cloth and all hair.
Should I be using that instead of going back to the Cloth room?
Should I be turning off the 'drape from zero pose'?
It worked so nicely the first go round.   It's frustrating.
pjz99 ( ) posted Tue, 28 July 2009 at 3:48 PM
Ah you're trying to treat that hair as dynamic?  Good luck with that, I'm surprised you got it to complete even once.
My Freebies
nruddock ( ) posted Tue, 28 July 2009 at 5:18 PM
It's clear from the picture that you've got intersections between the hair and the figure's ears.
The cloth simulator is pretty much guaranteed to blow up.
MistyLaraCarrara ( ) posted Wed, 29 July 2009 at 11:57 AM · edited Wed, 29 July 2009 at 11:59 AM
I was simulating the SKIRT!  Not the hair      are you teasing me? :huh:
anyhoo, saving dynamic clothes to the library is futile.
my stein is empty.
pjz99 ( ) posted Wed, 29 July 2009 at 3:03 PM
I'm sorry, I got the idea that you had set the hair up as dynamic.  If the skirt is the only object that has been Clothified, then I think your problem is one of two things:
  1. There may be some geometry for the skirt that is actually inside the character's body, or intersecting itself, and is getting squirted out of the head eventually through bad luck;
  2. You have a bugged version of V4 and need to download the updated version, install it, and run the "Update V4" script.
My Freebies
