Mon, Jan 27, 8:16 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 5:49 pm)
Subject: ok Morph Guru types, what am I doing wrong :)
Fugazi1968 ( ) posted Wed, 29 July 2009 at 12:42 PM · edited Fri, 09 August 2024 at 6:53 PM
ok exported body part as Morph Target.
Used objaction scaler to scale up
made my changes in 3d coat
exported
Used objaction scaler to scale down
selected part in Poser, loaded in Morph Target file
Moved dial to 1 and this is what I get, a bad case of the mumps by the look of it.
The white face is the MT file imported, I thought it might be a scale thing but it seems not.
Any ideas?
John .
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
ockham ( ) posted Wed, 29 July 2009 at 12:59 PM
Looks like the X scale is higher than the others.
Until a better answer comes along:  Could it be that the head in the
original was actually scaled up slightly, perhaps "silently" by a FBM?
And then you applied the morph to an unscaled head?
My python page
My ShareCG freebies
Fugazi1968 ( ) posted Wed, 29 July 2009 at 1:01 PM
I get your drift, since the face is g4, which is a v4 morph. maybe there is some shenanigans going on.
Cheers I will check it out
John
Quote - Looks like the X scale is higher than the others.
Fugazi1968 ( ) posted Wed, 29 July 2009 at 1:10 PM
Cheers Ockham :) I did a test just using V4s head and it workes as expected, not sure what to do about G4 though :) tie for some digging I think.
John
FrankT ( ) posted Wed, 29 July 2009 at 1:48 PM
The problem is, you are applying the G4 morph twice in effect.
Once when you load the G4 morph and again when you apply your morph (which contains the G4 morph - if that makes sense)
My Freebies
Buy stuff on RedBubble
MikeJ ( ) posted Wed, 29 July 2009 at 2:51 PM
Yeah when you export a body part to use to make a MT you have to make sure that there aren't any morphs already applied to it, or as FrankT pointed out, you end up stacking morphs.
Fugazi1968 ( ) posted Wed, 29 July 2009 at 2:55 PM
Cheers dudes :) schoolboy error on my part there :)
wdupre ( ) posted Wed, 29 July 2009 at 8:40 PM
there is a way to fix that problem without starting from scratch, the way do it is apply your morph at 100% and than apply the girl morph at -100% . than save the result, that will give you just the bits of the morph that you changed. you can than spawn that as a new morph.
Fugazi1968 ( ) posted Wed, 29 July 2009 at 8:42 PM
Quote - there is a way to fix that problem without starting from scratch, the way do it is apply your morph at 100% and than apply the girl morph at -100% . than save the result, that will give you just the bits of the morph that you changed. you can than spawn that as a new morph.
top tip :) thanks lods, I was wondering how you could do that .
john :)
