Sun, Jan 12, 12:02 PM CST
Photography F.A.Q (Last Updated: 2024 Dec 31 10:42 am)
Subject: Photo Stacking - Macros
NightGallery ( ) posted Thu, 30 July 2009 at 7:15 PM · edited Sun, 12 January 2025 at 11:56 AM
Attached Link: Stack image
Linked Image info: Top image First shot with focus on the eyes. Bottom Complete 4 image stack.
Something I have seen around here and there on the web which is new to me is called "Stacking"  Only seen it used in Macro myself. It is basically taking photos with different focused points and combining those images to create a single shot with more sharpness/DOF through the image.
I haven't really looked into it and don't know if there are programs that help you do it or not. Just wanted to share my first venture into this using more that 2 shots. I have posted a couple here with 2 images put together. But this one was using 4.
I took all 4 using a tripod. Focused on the eyes first, then the thorax, then the abdomen (x2). What I found was that; each focused shot was slightly different in magnification. I think this is because I use a standard Tripod and changed the focus on the lens. Rather than using a slide which would keep the lens at the same mag. but move the camera itself. (Hope that makes sense.) So I had to adjust the size of each image in my editor program (Corel Photopaint X4). Making each one slightly transparent and reducing it to match the underlying layer shot.
Anyway, just wanted to share and see if anyone had any other info/tips about this stuff. Its a pretty cool thing for bugs (or any macro) that will sit for a while you can get the shots.
-Bruce
Wojteg ( ) posted Thu, 30 July 2009 at 7:32 PM
Hello!
Thanks for sharing Your secrets with us.You did magnificent job on this image.There is special program ,which do it for You,it is called Helicon Focus and You cab find detailed review about it here
http://luminous-landscape.com/tutorials/Helicon.shtml
Greetings.........................Wojtek
PS.You are right about differences in images.You will need a slide to make it correct or above software(pretty expansive)
NightGallery ( ) posted Thu, 30 July 2009 at 8:02 PM
Cool deal, thanks for the info. I will check it out for sure. Appreciate it.
TomDart ( ) posted Thu, 30 July 2009 at 8:26 PM
I am glad the bug did not move that much for the shots taken!  I have used combined images at times but not posted here as I recall, mostly in attempts to produce good illustrations of jewelry and similar items.  These objects by nature require different lighting for various parts of the shot, i.e. gemstones needing more of a point source of light and metals needing some diffusion to reduce reflection. Diffusion simply kills the lighting of gemstones and bright light with no diffusion kills photos of metals..so, a combination is needed generally in my attempts by selections and not stacking of complete images, if that is what you are doing. As for this sort of image, Thundering knows lots more than I do.
Interesting thoughts you give us here.         Thanks.          Tom.
NightGallery ( ) posted Thu, 30 July 2009 at 9:25 PM
Thanks Tom. Interesting stuff about the diff. lighting on different materials.
-B
helanker ( ) posted Fri, 31 July 2009 at 1:45 AM
Yes it looks fabulous. Thanks for the info :-)
ejn ( ) posted Fri, 31 July 2009 at 1:54 AM
If you mean what I think you mean CS4 does it automatically.
NightGallery ( ) posted Fri, 31 July 2009 at 1:57 AM
Quote - If you mean what I think you mean CS4 does it automatically.
Interesting! I will look into their features
ejn ( ) posted Fri, 31 July 2009 at 2:22 AM
I saw a video on it on Adobe TV.Worth watching it. I think it was a female showing what is new in CS4.
danob ( ) posted Fri, 31 July 2009 at 8:50 AM
Yes very interesting technique one of the features of CS4 I pointed out in the review
Danny O'Byrne  http://www.digitalartzone.co.uk/
"All the technique in the world doesn't compensate for the inability to notice" Eliott Erwitt
odeathoflife ( ) posted Mon, 24 August 2009 at 4:23 PM
there is a HRD merge in Paint shop pro photo that does this sutomatically as well...I have used it a couple of times but nothing spectacular :)
Those are both really nice pictures.
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
