Wed, Jan 22, 1:01 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 12:55 am)
Subject: depth of field fuzzies?
MistyLaraCarrara ( ) posted Thu, 30 July 2009 at 9:43 AM · edited Wed, 22 January 2025 at 12:58 AM
well, at least the center character has the focus.
but, those fuzzies along the background edges, there has to be a way to improve that?
thanks.
cheers!
hborre ( ) posted Thu, 30 July 2009 at 10:27 AM · edited Thu, 30 July 2009 at 10:28 AM
Yes, there is a way to improve the quality of the DoF.  Set your render settings for Pixel Sampling to 15.  It will increase your render time but the DoF will sharpen considerably.
replicand ( ) posted Thu, 30 July 2009 at 11:41 AM
Like Hborre says, increasing your pixel samples will smooth the image at the expense of render time (but it will look awesome). I'm a big fan of larger apertures / smaller f-stops for really dramatic DoF.
MistyLaraCarrara ( ) posted Thu, 30 July 2009 at 12:39 PM · edited Thu, 30 July 2009 at 12:43 PM
Have you ever maxed out the pixels?
replicand ( ) posted Thu, 30 July 2009 at 12:48 PM
Theoretically there would be no limit to the amount of sample you could take but I'd say 20-25 would be the practical limit where you would notice no difference in quality.
As Hborre suggests, start at 15 and increase until you get the smoothness you're looking for.
R_Hatch ( ) posted Fri, 31 July 2009 at 6:23 AM
Or render out a non-antialiased zbuffer image and use DOF Pro with Photoshop/Paint Shop Pro/etc. This method also gives you the added advantage of being able to interactively choose a focal point after the render is done.
MistyLaraCarrara ( ) posted Fri, 31 July 2009 at 10:38 AM
I keep getting the white milky screen.
It won't render a higher pixel sample to save it's life.
I did learn from my night of  Depth Fuzzies,
when Vista crashes Poser during a render, the FFrender.exe keeps on running.
MistyLaraCarrara ( ) posted Fri, 31 July 2009 at 10:40 AM
If only there was a 'render to disk' option, like Bryce has.
I was watching TaskManager before the crash, a highlight line was bouncing between Poser.exe and FFrender.exe.
ima70 ( ) posted Fri, 31 July 2009 at 12:44 PM
When I need depth of field I use this way:
www.keindesign.de/stefan/poser/dof_tutorial.html
Way faster than the slow Poser option (or try DazStudio 3 one that's really fast, hope SM "fix" this in Poser 8)
