Sat, Feb 8, 6:01 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 8:53 pm)
Subject: help me??? ^o^
AnyMatter ( ) posted Sat, 01 August 2009 at 11:53 PM · edited Sat, 08 February 2025 at 5:56 AM
hi
anyone regconized bikini babe for aiko 3??? i have this problem, please look at the pic, the shoulder poke thru her outfit.... i don't have any idea on fix this unless there is jcmcollarbend, magnet fits..... any solution??? note: the figure is already conformed to aiko3.
Acadia ( ) posted Sun, 02 August 2009 at 12:09 AM
When you select the clothing, are there body parts to the top? For example: chest, collar? If so, you can try adjusting the parameter dials for those parts of the outfit.
If there are no morphs in the clothing, there are programs that you can buy that can add the body morphs to the clothing.
chriscox ( ) posted Sun, 02 August 2009 at 4:31 AM
You already identified the problem.  It is JCMrCollarBend,  If the top has the JCMrCollarbend in its rCollar you should be able to adjust that to fit Aiko.  It the top does not have the morph you could try adding it as Arcadia through use of a program or magnets.  An alternative would be to select Aiko's rCollar and adjust the JCMrCollarBend there to fit the clothes.
Chris Cox
