Mon, Feb 3, 10:54 PM CST
Forum Moderators: Staff
Subject: Poser Runtime Menu
rocker333 ( ) posted Sat, 01 August 2009 at 6:01 PM · edited Mon, 03 February 2025 at 10:52 PM
I am having a problem getting the library folder menus to act right. You know when you click and can scroll through the figures, poses, etc menu. I click 'build folder menu' but nothing happens. I hope someone can help me on this, as this is very annoying! LoL.....thanks.
Blessings, Shirley
rocker333
ockham ( ) posted Mon, 03 August 2009 at 4:41 PM
I don't know if there's a definite fix for this.  I've seen it happen for a while,
then it stopped happening for no obvious reason.
If it's really annoying, you could try the old "delete preference files" trick.
Locate "Poser.ini" on your computer, and delete it along with PreferredState.pz3.
This may or may not help.
My python page
My ShareCG freebies
rocker333 ( ) posted Mon, 03 August 2009 at 4:54 PM
Thank you for your reply. I will try this if it keeps on happening.
Blessings, Shirley
fmorgan ( ) posted Mon, 03 August 2009 at 7:21 PM
 It happens also to me. A workaround is to load first an empty (or small) runtime, and then the big one, and when build menu actually works.
rocker333 ( ) posted Mon, 03 August 2009 at 7:31 PM
I tried deleting the library prefs file, and that worked. I appreicate the help and suggestions. My Runtime is so huge that it would take a long time to find what i want without being able to scroll through the menus. :-)
Blessings, Shirley
