Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 28 11:11 am)
Thank you
R I P MJ. He's must have needed an Angel escort in
Farrah
Please spay and neuter your pets. Strongly consider shelter
adoption before spending $500 to $1000. If you MUST part with that
kind of money for a pet, go to your local shelter, donate the money
to them and pickup a highly adoptable pet. The shelters could sure
use the donation.
The "Map size" in the Light parameters refers to the Shadow Map size. This is only relevant if the lights are using Depth Map shadows. It might be what they are referring to - I don't know this light set or what type of shadows it uses.
But if the lights are using image maps, they might mean the "Image_Resolution" dial in the Light node (click on the Advanced material properties button shown above).
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
That's correct it was snow sultan's illustrators light.
Farrah
use the donation.
Greetings All,
I downloaded "illustrator lights" from rendo freebies. In one of the read Me's it says "be sure to turn up the Light Map on each light to 1024 when rendering". Where is this setting located?
Many Thanks in Advance
Viper
R I P MJ. He's must have needed an Angel escort in Farrah
Please spay and neuter your pets. Strongly consider shelter adoption before spending $500 to $1000. If you MUST part with that kind of money for a pet, go to your local shelter, donate the money to them and pickup a highly adoptable pet. The shelters could sure use the donation.
