Wed, Jan 1, 1:24 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 01 1:14 pm)
Subject: ASIA model for Victoria2 question...
armand28 ( ) posted Mon, 16 July 2001 at 1:25 PM ยท edited Sun, 29 December 2024 at 2:05 PM
When I try to apply a face from the faces menu it says something like "This object refers to parts that aren't on your model.". It sounds like it's looking for a handle or morph point on my model that doesn't exist, but I know I've installed the character correctly. Anyone else have this happen to them?! Thanks
JKeller ( ) posted Mon, 16 July 2001 at 1:29 PM
Asia comes with custom morph targets that come as squeezed .obj files. You need to load these onto your figure and name them with the exact names that the readme describes in order for the face poses to recognize them. Hope this helps.
armand28 ( ) posted Mon, 16 July 2001 at 1:39 PM
I've imported the .OBJs in the readme, I think the ones were for the head, and left and right chest, but I'm still getting it. When I apply a face it SORTA does it, but not exactly. I'll try it again when I get home, thanks for the suggestion!
Marque ( ) posted Mon, 16 July 2001 at 3:28 PM
That's weird because I was able to use her for both Vickie 2.0 and 1.0 without any problems. I would suggest that you re-install the product. Marque
Jaager ( ) posted Mon, 16 July 2001 at 11:25 PM
This message probably means that there was at least one morph called for in the PZ2 file that is not in the CR2 that you used to accept the pose. The names of the morphs must be identical. It does not matter if the morph really is there if the name does not match. You can open the PZ2 in a text editor and find the morph that is called for which does not match. If Asia comes with a custom morph which you must apply in Poser, then the chances are this is the one. You probably did not name it the precise name required. Had the custom morph been supplied in a carrier CR2 and the morph copied to your main CR2 using MM4/MaCon - the required name would have copied over. This method also retains morph limits (+/- 10000 is not realistic for limits) and any ERC information.
