Fri, Feb 7, 8:43 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
Subject: Any one else noticed P8 Male issue?
nyguy ( ) posted Thu, 13 August 2009 at 9:29 AM · edited Wed, 05 February 2025 at 6:08 AM
I am not posting any images of P8 Male's "toast" but I did notice in the preview it looks like the normals are reversed. Has any one else notice this? I rarely do any nude images of males but I was checking out how the male looks. I also think his "toast" looks very unrealistic.
Poserverse The New Home for NYGUY's Freebies
TZORG ( ) posted Thu, 13 August 2009 at 9:36 AM
On real toast the normals can get reversed sometimes if sticky.
It's not the tool used, it's the tool using it
MistyLaraCarrara ( ) posted Thu, 13 August 2009 at 9:39 AM
You'll have to 'post the toast' if you want it evaluated properly.
PhilC ( ) posted Thu, 13 August 2009 at 9:42 AM
If you select the toast and click on the menu "Drop to floor" it will always land polygon side down.
thinkcooper ( ) posted Thu, 13 August 2009 at 11:35 AM
Quote - I am not posting any images of P8 Male's "toast" but I did notice in the preview it looks like the normals are reversed. Has any one else notice this? I rarely do any nude images of males but I was checking out how the male looks. I also think his "toast" looks very unrealistic.
In the Render Settings>Preview>Transparency Display, check on "Enhance Multilayer Transparency" to correct the display of his block and tackle. This setting can also improve the display of some multilayered transmapped hair props, but it can be slower when interacting with the scene. I prefer to use the option only as needed.
Steve Cooper
Poser Product Manager
ziggie ( ) posted Thu, 13 August 2009 at 1:16 PM
Quote - If you select the toast and click on the menu "Drop to floor" it will always land polygon side down.
That... made me lose half a mug of coffee..!
"You don't have to be mad to use Poser... but it helps"
hborre ( ) posted Thu, 13 August 2009 at 1:21 PM
Online Now!
Hmmm, nyguy checking out another guy's junk?  This may be cause for concern.
nyguy ( ) posted Thu, 13 August 2009 at 1:26 PM
Quote - > Quote - I am not posting any images of P8 Male's "toast" but I did notice in the preview it looks like the normals are reversed. Has any one else notice this? I rarely do any nude images of males but I was checking out how the male looks. I also think his "toast" looks very unrealistic.
Steve Cooper
Thanks  for the info
SeanMartin ( ) posted Thu, 13 August 2009 at 1:26 PM
They're just very, very shy....
nyguy ( ) posted Thu, 13 August 2009 at 1:27 PM
Quote - Hmmm, nyguy checking out another guy's junk?  This may be cause for concern.
Now that is getting a little to personal for my tastes
TZORG ( ) posted Thu, 13 August 2009 at 1:33 PM
I actually thought Phil was being serious, that this was a way to see if there were reversed normals. Then I remembered about toast, like real toast. Ahaha.
TrekkieGrrrl ( ) posted Fri, 14 August 2009 at 7:59 AM
 I think their tackle looks great. And morph-wise (and movement wise) they're among the best, perhaps only surplussed by Satanica's replacement - and that is after all rather costly.
The reversed normal/transparecy issue is wellknown in Poser, and epecially the genitals suffers a lot from it for some reason. But since they RENDER ok.. what's the problem?
nyguy ( ) posted Fri, 14 August 2009 at 8:17 AM
Quote - what's the problem?
No problem, just wondering if there was a problem due to the way they display in preview.
