Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Had that happen today. Clicked the refresh and Poser just disappeared.
There are a lot of things worse than dying, being afraid all the time would be one.
I have experienced similar issues with the library just recently, and but I couldn't tell if it was because I had 4 programs running. Now I only use Poser 8 without any other programs running so that I can start documenting any issues that may happen.
Frederick
Poser By Design
I had both behaviours: Poser disappearing instantly and the "Poser encountered an error" (or similar, I have a German version of WinXP Pro Sp3 8-) and the error details in the first post. This occured even if it was not a top level runtime folder.
I also installed the latest version of the Flash Player after I installed Poser 8.
The error signature is in the attached png (screenshot).
This is pretty much the only stability issue I have with Poser 8, but it is quite disappointing if you have to close the program and restart it to see something you have just copied to the runtime
