Thu, Nov 28, 3:35 PM CST
Subject: poser : rendering in passes
  • 1
  • 2
ice-boy ( ) posted Thu, 20 August 2009 at 2:11 AM
maybe you can copy/paste whats in the script?
IsaoShi ( ) posted Thu, 20 August 2009 at 4:04 AM · edited Thu, 20 August 2009 at 4:08 AM
file_437482.txt
Posting in this thread also, in case others need it.
This is the script by markschum which he has made freely available.
Mec4D use this one too.
(edit) the script comment says "Probably only Poser 6 or 7".
At the time it was written this meant: "Probably not Poser 5 or earlier".
Lucifer_The_Dark ( ) posted Thu, 20 August 2009 at 4:19 AM
Getting the separate renders out of Poser is the easy bit, how do you go about assembling them properly in your favourite paint package? specifically in what order do they go?
Windows 7 64Bit
Poser Pro 2010 SR1
ice-boy ( ) posted Thu, 20 August 2009 at 4:41 AM
getting seperate renders out of poser is easy?
not to me. it is to you?
Lucifer_The_Dark ( ) posted Thu, 20 August 2009 at 6:00 AM
Well compared to the part where you use photoshop or gimp to combine them it is, a couple of clicks & bob's your uncle.
Windows 7 64Bit
Poser Pro 2010 SR1
ice-boy ( ) posted Thu, 20 August 2009 at 6:28 AM · edited Thu, 20 August 2009 at 6:32 AM
i never do every pass.
a lot of times i do an AO pass for some tweaking. and if i have  something glowing in the scene then i also do a seperate pass so that i can then do a glow effect.
sometimes i also do an ''light matte''. like i was talking about. that way i have 100% control what color the lights is. it becomes very practical when you do color correction and you want fantasy colors.
if i do an AO pass then i turn of shadows and turn on shadow only. if you only have IBL turned on and shadow only set then you get an AO pass.
i think a ''reflection pass'' would be very good. is there any python script for that? so that we could render out only reflections?
  • 1
  • 2
