Sun, Feb 9, 2:23 AM CST
Subject: Rapid, ugly repetitive atmosphere color changes
corysea ( ) posted Wed, 19 August 2009 at 2:03 PM · edited Tue, 04 February 2025 at 7:39 AM
Attached Link: http://www.guitarcory.com/page4.html.
Dear Friends,
I'm getting these rapid and ugly color changes in my render. The render is 25 fps, 758 by 576, final.
I'm using Vue 7.5 infinite on a Vista 64 computer. The scene has a volumetric atmosphere, no cloud movement. There are stars and ice rings and blue color haze. The ground plane has a water material for which the animate material surface is checked. Please go to this URL to see a few seconds of the scene. I appreciate any help.  http://www.guitarcory.com/page4.html.
Many thanks,
Cory sea
Rutra ( ) posted Wed, 19 August 2009 at 2:13 PM
Your 1st link shows a 404 error.
Your 2nd link points to a strange thing (cid:part1.00050800.00090602@deeplyheal.com).
bruno021 ( ) posted Wed, 19 August 2009 at 2:42 PM
So, it wasn't the lens flare?
ShawnDriscoll ( ) posted Wed, 19 August 2009 at 3:45 PM
Do we need DivX codec installed to view your AVI?
ArtPearl ( ) posted Wed, 19 August 2009 at 4:26 PM
It's possible to watch the first link if you remove  the dot at the end of the link.
But I know nothing about making movies in Vue, so cant help a  lot. Does it look any different if you just render  one still?
"I paint that which comes from the imagination or from dreams, or from an unconscious drive. I photograph the things that I do not wish to paint, the things which already have an existence."
Man Ray, modernist painter
http://artpearl.redbubble.com/
Rutra ( ) posted Wed, 19 August 2009 at 5:09 PM
Ah, I saw it after taking the dot out.
Yes, really ugly and strange. I noticed the sun seems to be pulsating in synch with the color change. Did you animate any feature of the sun?
ShawnDriscoll ( ) posted Wed, 19 August 2009 at 5:44 PM
Ok.  It just needs at least Media Player 10 to view.  I had version 9 on this computer.
bruno021 ( ) posted Wed, 19 August 2009 at 5:57 PM
I suggested at C3D this could come from the sun lens flare, it looks animated, small, then big, then small again. The guy said he was rendering without it, but no news since.
Mazak ( ) posted Wed, 19 August 2009 at 6:21 PM
Check in atmosphere editor "Forbid atmosphere animation"
Mazak
Google+ Bodo Nittel
corysea ( ) posted Wed, 19 August 2009 at 7:44 PM
corysea ( ) posted Wed, 19 August 2009 at 7:49 PM
Thanks, everyone. Yes, I guess  you need dvix installed to view the video. Thank you for bringing this up. I've taken out the lens flare and this seems to make no difference. I notice it takes about two to three times longer to load this particular Vue file into vue. I'm going to try to render some other things to see if they show the same problem.  Apart from the balloons, the only other thing animated is "animated materials-foam".
Cory
corysea ( ) posted Wed, 19 August 2009 at 7:51 PM
Thanks Mazak. I'm trying a render of the same scene right now with "forbid animation" checked. I'll let you know how it turns out.
Cory
corysea ( ) posted Wed, 19 August 2009 at 8:55 PM
corysea ( ) posted Wed, 19 August 2009 at 8:57 PM
Friends,
No different with "forbid animation" ticked. Could it be a problem with the video card (Nividia GeForce 8800 GT)?
Cory
ShawnDriscoll ( ) posted Wed, 19 August 2009 at 9:51 PM
The video card is only affected by OpenGL mode.  The video card does determine your total colors (i.e. 32-bit color) and screen resolution.
corysea ( ) posted Thu, 20 August 2009 at 3:43 AM · edited Thu, 20 August 2009 at 3:43 AM
Same thing happened with another (shipped with Vue) atmosphere. So I'm trying a different material for the water plane.
Cory
corysea ( ) posted Thu, 20 August 2009 at 5:18 AM
I removed the foam from the water mixed material and now I don't have the problem. Strange.
