Sat, Feb 15, 4:14 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Subject: Huh? I didn't know the image node could use .psd files
MistyLaraCarrara ( ) posted Thu, 20 August 2009 at 10:30 AM · edited Thu, 13 February 2025 at 4:33 AM
Are there advantages to using a .psd file, instead of .png?
hborre ( ) posted Thu, 20 August 2009 at 11:36 AM · edited Thu, 20 August 2009 at 11:37 AM
The only advantage I can imagine is quick editing in Photoshop while running Poser.  PSD files are quite hefty in the file size department and have the potential to bog down Poser performance.
BTW, Long Island?  Which part?
MistyLaraCarrara ( ) posted Thu, 20 August 2009 at 11:41 AM
Huntington/Greenlawn area.
Are you near?
pjz99 ( ) posted Thu, 20 August 2009 at 11:55 AM
I strongly suspect it can't interpret things like adjustment layers or other tricky things you can do with PSD files, so overall IMO it's a lot simpler to use one of the flat image formats.
My Freebies
Faery_Light ( ) posted Thu, 20 August 2009 at 12:14 PM
I only use psd when first testing my textures and before making the material poses, then I use the jpeg files.
PSD files get wayyyy too large and will crash Poser if you haven't enough memory.
lmckenzie ( ) posted Thu, 20 August 2009 at 1:37 PM
They've been supported as textures since Poser 4 at  least, don't know about 3. I believe that some apps like C4D will allow you to load PSD layers into different material channels, though as pjz99 says I doubt that Poser has the ability natively. BB might be able to find a way to do it but ach the file sizes. If I wanted to view changes while in Poser, I'd probably just export the revisions to .jpg.
Something interesting is the "layered image editor" plugin for DS which will apparently let you use .jpg files and create layers for things like tattoos and then apply them with a MAT file. Sounds a lot simpler than doing it with nodes.
LostinSpaceman ( ) posted Thu, 20 August 2009 at 3:36 PM
Quote - Are there advantages to using a .psd file, instead of .png?
Image nodes can use several formats including PNG, PSD, JPG, TIF, GIF........
hborre ( ) posted Thu, 20 August 2009 at 3:40 PM
Medford, further east.
