Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
So, I should check out the tr jpg. Thanks!
That is the Mark hair btw.
I had to use my handy dandy franken morph to squeeze James's head under it.
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
How did you export this image from Poser? More specifically, where did the white background come from?
I suspect that you did not render over black, so the Poser background colour bleeds through into the semi-transparent pixels in the hair, giving the grey pixels that you see there. You can fix it like this:
Use the render setting "Render over: Black". Export the render as a PNG image, which maintains transparency. Then you can put your image onto whatever background you want and you won't have the grey mixed in with the semi-transparent pixels.
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
I orig export my renders to a png file and when I saved it to jpg to post it here, background automatically turned white.
Let's see if renderosity will let me attach the png file
and i see i have render issue with David's knee. another job for the blur tool.
it must be psychological, but i just noticed when I mix Daz and Poser characters in a scene, i tend to make them a little oppositional.
oops, I'll have to resample it down.
sigh, I should just put him back into the Kozaburo ponytail.
If the "background automatically turned white", the original render PNG must have had a transparent background. So go back to my suggestion for fixing the problem. Did you try it?
what I should be."
Murakami)
not yet. I'm searching to see if anyone has put out add-on mats for the mark hair.
I tried putting my own hair on the flatbed scanner. that method isn't working out too well.
Okay, maybe I misunderstood the problem. I thought you wanted the hair to look less wispy and semi-transparent. That's just what render over black will do for it. :O)
what I should be."
Murakami)
Kewl, IsaoShi, I'm glad I read this thread - never noticed that option before, or at least, if I did, I had no clue what it was for. :)
______________
It's not that its too wispy, I wanted it to look a little less not-realistic. (if i may use a double negative here.)
There was a separate specular map of shaded gray.
I spent the rest of the night trying to fit Michael's Valiant/highlander to James.
Our poor James needs more options.
Getting old and still making "art" without soiling myself, now that's success.
![file_437505.jpg](https://live.cdn.renderosity.com/forum/threads/2779857/file_437505.jpg)
I've been trying to tweak fall off, etc, to make it look less, how do you say, transmappy-ish.(I'm giving up on dynamic hair for long hair for now. Long long hours for naught.)
