Fri, Dec 27, 7:46 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 27 7:02 pm)
Subject: Can u make this pose for me?
ViperKilzz ( ) posted Fri, 21 August 2009 at 11:51 AM · edited Fri, 02 August 2024 at 9:25 PM
Greetings,
I've been trying to duplicate this pose for a couple of days without much success. I'm getting frustrated. I was wondering if someone more experienced with creating poses could make it for me? Please!
I've enclosed a photo. It's the pose on top of the radio.
Many Thanks in advance for any help.
Viperkilzz
R I P MJ. He's must have needed an Angel escort in Farrah
Please spay and neuter your pets. Strongly consider shelter adoption before spending $500 to $1000. If you MUST part with that kind of money for a pet, go to your local shelter, donate the money to them and pickup a highly adoptable pet. The shelters could sure use the donation.
Acadia ( ) posted Fri, 21 August 2009 at 11:58 AM
I can't do the pose, but you need to specify for which figure you are wanting the pose for because there are joint issues involved.
V4? V3? M3? SP3? Other?
ViperKilzz ( ) posted Fri, 21 August 2009 at 12:00 PM
thanks for the heads up, Acadia. This would be for V4
lkendall ( ) posted Fri, 21 August 2009 at 12:06 PM
I am at work, so I cant do this now. You need to rotate the hip (if you haven't figured it out already). Chose the hip, and use the rotation settings in the Parameters tab. After the hips are rotated so that V4 is laying flat, the rest of the pose should be easy.
LMK
Probably edited for spelling, grammer, punctuation, or typos.
raven ( ) posted Fri, 21 August 2009 at 1:19 PM
How's this?
raven ( ) posted Fri, 21 August 2009 at 1:24 PM
file_437630.txt
If you want it, save the attachment without the .txt at the end. You should end up with a zip file called VK_pose.zip which you can then extract to your Poser install, although I'd recommend a temporary place where you can then move it to wherever you want. After unzipping, it will reside in a folder called ravens_misc_poses.
ViperKilzz ( ) posted Fri, 21 August 2009 at 3:22 PM
Raven:
Thank you so much. Link you when I post
pakled ( ) posted Sun, 23 August 2009 at 11:15 AM
check out Most Digital, they're almost up to a 100 pose kits for V4 alone, should be something in there...;)
You might look for Adam Thwaite (sp?), who's connected with them.
