Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 4:20 pm)
No real problem here. For your first question set up your magnet for the object in question and then select Object then spawn morph target. When you export just have that morph target dial set at 1.0 or whatever. Export Wavefront Obj>Single Frame>(Only check the part you want to export), depending on your version of poser 4 or poser pro you well get a window in which you can select how you want to export it, All you need to have checked is the last one As a morph target. You can also save your magnets by opening your props menu, then click the + to add the selected magnet(s) as a prop.
Is there a way to save a magnet's result as a morph target? If I have added and adjusted a magnet to deform an article of clothing, is there a way to save that final deformation as a morph dial for that clothing item? So that if I want to reproduce it again all I have to do is load the modified piece of clothing and crank up the morph dial? This would also make my morphs distributable, so that I could put them in free stuff. If anyone knows how to go about doing this I would appreciate any help, or ideally a step-by-step walkthrough since I have limited experience with morph creation. If the above is impossible, is there another way to do this, possibly by saving the magnets? And if so, how do I re-apply them again? Cheers -Gabriel
