Fri, Jan 31, 11:11 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: I have a questions about lights.
FightingWolf ( ) posted Tue, 25 August 2009 at 10:14 PM · edited Sun, 19 January 2025 at 2:03 AM
I want to offer some of my lighting for free, but I'm not sure of what I need to do in order to get the light settings into a zip file.  Is there a script in poser similar to PoseWriter? What am I missing?
Is it something simple that I'm over looking? Thanks for any help with this.
Frederick
Poser By Design
Acadia ( ) posted Tue, 25 August 2009 at 10:21 PM
Winzip is what I use.
http://www.winzip.com/prod_down.htm
LaurieA ( ) posted Tue, 25 August 2009 at 10:24 PM
I have an empty runtime folder that I use already set up and just plop the files into their respective places in there and delete what I don't need, then zip that up.
markschum ( ) posted Tue, 25 August 2009 at 10:30 PM
Easy way to zip stuff is to make a empty runtime at the root level of the drive.
example c:runtime
then when you zip it up all the paths will be good.
For something like lights you can just zip them up with no path info , and tell people to extract it to poser 7/runtime/libraries/lights     cause you will just have the lt2 file and its thumbnail.
FightingWolf ( ) posted Tue, 25 August 2009 at 11:28 PM
Quote - Easy way to zip stuff is to make a empty runtime at the root level of the drive.
example c:runtime
What path would I use for it to work in all versions of Poser?
markschum ( ) posted Tue, 25 August 2009 at 11:37 PM
either zip into c:runtimeetc  or just tell people unzip without paths to their lights folder , let them worry about where there runtime is located .
lights are ..RuntimeLibrariesLight   and then subfolder if desired.
FightingWolf ( ) posted Wed, 26 August 2009 at 12:21 AM
Thanks for your help everyone..
  Thanks markschum.. I really appreciate the help.
Frederick
Poser By Design
