Fri, Jan 24, 5:57 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: face off's real skin shader
dimdedi ( ) posted Fri, 07 August 2009 at 6:47 AM · edited Wed, 15 January 2025 at 2:27 PM
Hi to all,
Does someone has tried this script with poser 8 ?
Thanks to all.
rty ( ) posted Fri, 07 August 2009 at 8:07 AM
Someone posted in one of the long threads that it works fine.
Marque ( ) posted Fri, 07 August 2009 at 4:52 PM
Need to find that thread because it doesn't work for me.
Netherworks ( ) posted Fri, 07 August 2009 at 4:56 PM
RealSkinShader from the Realism Kit works here.  I'm on XP-64
722 ( ) posted Mon, 07 September 2009 at 6:30 AM
in my poser 8 , it ony works for V4 and no other figure , Don't know why???
cspear ( ) posted Mon, 07 September 2009 at 6:50 AM
No problems here (Vista64, Poser 8). Try applying via the material room > wacros.
PoserPro 11 - Units: Metres
Adobe CC 2017
hborre ( ) posted Mon, 07 September 2009 at 8:45 AM
The script should work fine in P8 if you previously had no problems.  However, the script did need editing when P7 was introduced; the python script interpretation in the app failed to recognize "Col." and could not implement the script correctly.  The workaround, change every instance of "Col." to "Column".  For current script dedicated to V4, editing the script will make it compatible to M4.  The link below leads directly to the forum where you can find more detailed information:
http://www.physicalc-software.com/forum/
jeffg3 ( ) posted Mon, 07 September 2009 at 10:36 AM
You really should check out VSS. It's much better.
hborre ( ) posted Mon, 07 September 2009 at 10:53 AM
Yep, jeffg3, I agree VSS is superior in many ways.
lululee ( ) posted Mon, 07 September 2009 at 11:23 AM
What is Vss and is there a link to it?
cheerio
lululee
WandW ( ) posted Mon, 07 September 2009 at 12:51 PM
VSS is here:
http://poserbagginsbill.googlepages.com/vsshomepage
lululee ( ) posted Mon, 07 September 2009 at 4:42 PM
Thanks WandW.
cheerio
lululee
