Sat, Jan 11, 8:17 AM CST
Subject: Exporting Image Sequence
morphious ( ) posted Thu, 17 September 2009 at 7:55 PM · edited Mon, 23 December 2024 at 6:41 PM
I am using Queue Manager. It only does movies as sequences. What is the best format for web. And what is the best program to import and create a movie, and what is the best movie format for web? Sorry. Newbie here. Thanks.
Miss Nancy ( ) posted Thu, 17 September 2009 at 8:07 PM
I like uncompressed tiff, but if yer posting an img sequence on web, it would hafta be jpeg, png, gif or those compressed formats. the standard for posting movies on internet is now swf/flv (you-tube).
morphious ( ) posted Thu, 17 September 2009 at 8:09 PM
So, I should export as tiff, and import to flash, nd export movie?
Miss Nancy ( ) posted Thu, 17 September 2009 at 8:34 PM
my method is to export uncompressed quicktime movie (or tiff sequence, which is concatenated by quicktime), then convert that to swf using visualhub (OS X).  the main reason for exporting img seq. is that poser may crash during movie rendering.  however, some of them are saying that it apparently also crashes during routine non-rendering operations (P8 SR0).
morphious ( ) posted Thu, 17 September 2009 at 8:40 PM
Wait, I'm on PC. I am exporting to image sequence, only because Poser Queue Manager will only allow image sequence with a render farm (multiple computers rendering the same file) So what formt should I export out of poser? And most important, what program like Adobe AE should I export out as to look good on a website?
3dactor ( ) posted Fri, 18 September 2009 at 11:54 AM
 I   would export png format via the queue manager. This format is uncompressed and will leave a transparent background as an alpha channel if you desire.
Its been awhile since I have used After Effects, but every video application can import an image sequence.
I tend to assemble my image sequences in Photoshop CS4 Extended, but only because it is quick and easy  to import the sequence, change edit the background drop a logo layer in front and export as a .mov ( I am on a mac and prefer quicktime as my delivery platform) At this point the movie is still uncompressed which is important. I wouldn't add any compression until the last stage , which will be saving file for web delivery. So if you plan on exporting to flash. make sure the video going into the flash video conversion is uncompressed. if it is already compressed you end up with double compression and a lesser quality end result.
This is another reason to export image sequence over a quicktime movie. I tend to only render to a quicktime movie when I a doing proof and don't mind tying up poser for a little bit. most of the time I still send those lesser quality firefly renders to the render queue so I can keep working and quickly assemble them in Quicktime Pro  to check the proof.
anyway, hope that helps some.
JC-
