Tue, Jan 7, 12:57 AM CST
Subject: need help to share a morph.
scott8539 ( ) posted Thu, 17 September 2009 at 2:27 PM · edited Tue, 31 December 2024 at 7:59 PM
i made a yoda morph for m4 but i had to use scaleing and when i save it in the pose room it dose not save the scale info?i check bolth boxes when saving.using poser8 morhptool is a lot better but now my cr2 is almost 100 mb.
Porthos ( ) posted Thu, 17 September 2009 at 4:00 PM
Creating an INJection pose to create the morphs would be my preferred method - maybe worth a try?
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD 7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
lesbentley ( ) posted Thu, 17 September 2009 at 7:44 PM
Svdl has a script that will save scaling data to a pose file. You could use that script to save the scaling data, then use a text editor to merge the scaling pose with a delta injection pose.
scott8539 ( ) posted Thu, 17 September 2009 at 9:11 PM
thanks for the replys.ran into another problem with the arms braking when moved front to back.tryed to fix it with the joint editor but just made it worse.i will scrap it for now.
Porthos ( ) posted Fri, 18 September 2009 at 8:43 AM
That's a shame, hope you can work it out - great morph! :)
hoplaa ( ) posted Fri, 18 September 2009 at 9:24 AM · edited Fri, 18 September 2009 at 9:24 AM
That looks very good, just needs wrinkles (displacement or normal maps, I'd prefer the latter) :)
I'm sure many would appreciate just the head morph, the body isn't as important since scaling is pretty easy to do and it's covered in clothes (although no doubt someone wants to do pr0n with Yoda), and there may be some applicable morphs in the Creature Creator.
lesbentley ( ) posted Wed, 23 September 2009 at 5:32 PM
Quote - thanks for the replys.ran into another problem with the arms braking when moved front to back.tryed to fix it with the joint editor but just made it worse.i will scrap it for now.
Unfortunately scaling the chest chest can cause problems with rotations of the shoulder actors in many figures. Scaling the collar may also cause problems with rotations of the shoulder.
