Mon, Feb 3, 2:17 PM CST
Subject: .pz3 reader?
STRAFE52 ( ) posted Sun, 13 September 2009 at 5:14 PM · edited Fri, 31 January 2025 at 8:49 PM
I've heard that there is a program that can give a thumbnail or a preview of a .pz3 file. I have quite a few .pz3 files and this would be a help. Does anyone know the answer to this. Thanks.
TrekkieGrrrl ( ) posted Sun, 13 September 2009 at 6:29 PM
 I think P3DO can do it. Possibly the pro (paid) version. I have a vague idea of seeing my PZ3s that way, but I haven't used it for a while - I mostly just archive them L
Tashar59 ( ) posted Sun, 13 September 2009 at 9:22 PM
You could just do a quick preview render and save that with the same name as the Pz3. The render size is adjustable.
yarp ( ) posted Mon, 14 September 2009 at 1:00 AM
Attached Link: http://www.renderosity.com/mod/bcs/index.php?ViewProduct=72056&keyword=p3do
As TrekkieGrrrl said, P3dO has a PZ3 3D viewer and all kind of Poser files as well (CR2, PP2, HR2, even PZ2) compressed or not, zipped or not.
You have the ability to save a thumbnail from the P3dO render and thus create/override the Poser thumbnail.
You can also set that thumbnail from any Poser Render as Tashar59 said.
Once the PZ3 has a thumbnail P3dO will show both the PZ3 and its thumbnail in the same cell (as it does with other Poser files).
Limits:
The PZ3 render in P3dO is not accurate. It is not as complete as Poser render, so don't expect P3dO to be able to display complex scenes. But you will be able to figure out what is in the PZ3.
Yarp
Yarp - author of P3DO Organizer for Poser
TrekkieGrrrl ( ) posted Mon, 14 September 2009 at 6:15 AM
 Ah I thought it was P3DO ^_^
Thanks for clarifying. I really should use that program more. Whenever I use it I love it. But I tend to forget about it >_< I have too many Poser-related programs L
Yarp, now that you're here.. P3DO will load content directly into Poser 8, right? I think I saw that somewhere in relation to the miniscule library icons thing...
yarp ( ) posted Mon, 14 September 2009 at 7:20 AM · edited Mon, 14 September 2009 at 7:25 AM
Hi TrekkieGrrrl, I have got the same problem with this too ambitiuous software. I don't forget about P3dO but I sometimes forget about Poser. I have too many 3D softwares to look after ;)
Yes, P3dO now opens directly into Poser without the need of Prpc.
This feature is not related to P8. Any Poser is ok and I even managed to make it available with Poser Pro pack.
This has been made available with P3dO 2.2 (last May). I had to fix a minor bug with P8, this is probably what you saw. So you must have P3dO 2.2 (or P3dO pro 2.2 in your situation) and install the upgraded Poser Plugins Pack for P8:
http://www.senosoft.com/downloads/p3doposerpack220.zip
As you can guess it is a fantastic improvement.
Yarp
TrekkieGrrrl ( ) posted Mon, 14 September 2009 at 10:25 AM
 Wee! Downloading now. Can't wait to play. I'm usually using PBoost but that won't load anything into P8.. not sure why. I'd rather use P3DO then :)
Now if I could change my PBooost banks with it L... oh well.. I can do that manually.. just takes a little work. PBooost seems deserted, nothing new on the page since 2008 :(
yarp ( ) posted Mon, 14 September 2009 at 12:47 PM
I don't know PBooost very well, but I think that Banks are just Runtime switching, aren't they ?
Then it is not very difficult to do in P3dO.
Please pm me at sales_at_senosoft_dot_com so that we can see what I can do about this.
Anthanasius ( ) posted Mon, 14 September 2009 at 2:47 PM
Quote - You could just do a quick preview render and save that with the same name as the Pz3. The render size is adjustable.
The most economical solution with an explicit name for the file :-)
Génération mobiles Le Forum / Le Site
pakled ( ) posted Mon, 14 September 2009 at 5:30 PM
I use P3do a lot; need to transplant 20,100+ thumbnail images into a database (now there's tedium...;)
Joe Bob says check it out...;)
simontemplar ( ) posted Sun, 27 September 2009 at 11:40 AM
I could really do with an explanation of how P3Do can be used to replace pBooost. I am a bit lost since I can't use it anymore :/
yarp ( ) posted Sun, 27 September 2009 at 2:44 PM
Hi simontemplar,
there's nothing special to do. P3dO is an explorer, as a starter use it like the Explorer.
In order to open a file from a Pbooost bank into Poser simply double-click it in P3dO (there's nothing to set in Poser - no Prpc Python listener in Poser- ).
Unfortunately P3dO will not rename Banks on the fly and thus you won't be able see this stuff in Poser like you did with PBooost. So if you have Poser 4 you have a problem.
I have already discussed this with a former PBooost user about this. He told me the above was enough for his needs but I can add Banks support to P3dO.
Please contact me at sales_at_senosoft_dot_com if you want to discuss about this.
btw P3dO 2.2.5 is coming - very- soon ;)
Yarp
www.senosoft.com
