Tue, Nov 12, 9:51 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 12 9:45 pm)
Subject: Poser needs a damned STOP button.
dasquid ( ) posted Mon, 05 October 2009 at 1:05 PM · edited Tue, 12 November 2024 at 9:51 PM
Yeah that's right I said Poser needs a stop button. Ever been working on a scene and you are kind of in a hurry? sure enough when your time is ticking down to where you'll have to leave and you want to start the render before you go but poser isn't having any of that shit ,no it is taking 5 minutes to load a fucking character!
I want a fucking STOP!! button like the one that is on my browser that will make poser stop whatever the fuck it is doing and let me try something else!
TZORG ( ) posted Mon, 05 October 2009 at 1:23 PM
Poser says stfu and let me do my magic, biatch
It's not the tool used, it's the tool using it
EClark1894 ( ) posted Mon, 05 October 2009 at 1:26 PM
Alt - Q, good buddy!  Command Q on a Mac.
DarkEdge ( ) posted Mon, 05 October 2009 at 1:33 PM
The stop button it does has doesn't work so well either. I'll click cancel during a render and sometimes have to wait, wait and wait again...for it to finally stop.
grrrrrrrrrr
funny response tzorg 😄
pwiecek ( ) posted Mon, 05 October 2009 at 6:59 PM
Its better than it used to be. Cancelling used to take much longer than it does now.
pakled ( ) posted Mon, 05 October 2009 at 7:29 PM
isn't it next to the 'make art' button?...;)
Worse case (if you have XP, etc) - Ctrl+alt+del, task manager, then select the Poser line under the Application tab, and 'End Task'
LadyElf ( ) posted Mon, 05 October 2009 at 8:44 PM
P8 cancel works waaaayyyyy faster for me then P7 or P6 did.
I've also learned the value of the 1/2 and  1/4 render choice :)  I really like that.
Acadia ( ) posted Mon, 05 October 2009 at 9:31 PM
Quote - Its better than it used to be. Cancelling used to take much longer than it does now.
If I recall correctly, in Poser 5 the cancel button didn't work and in order to cancel the render you had to CTRL ALT DEL and bye-bye to your scene if you forgot to save it before hand!
jartz ( ) posted Mon, 05 October 2009 at 9:58 PM
Quote - > Quote - Its better than it used to be. Cancelling used to take much longer than it does now.
You are so right, Acadia.  There's ever a time when I have to sacrifice what scene I made and render, it would lag and lag and lag or when I'm doing something else, it would just freeze; then I have to use the Close bottom at the top to fully come to a complete halt.
The good ol' saying: Save first, save often... really rings true.  I wish there was a 'stop' button when you think about it.
JB
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
Miss Nancy ( ) posted Tue, 06 October 2009 at 12:51 AM
in other 3d apps (OS X), cmd-. or esc are standard ways to allow user to stop an operation without quitting.  however, they don't work in poser.
dasquid ( ) posted Tue, 06 October 2009 at 3:09 AM
Yeah I actually mean examples where you go to load something and  the damned thing just keeps taking forever.
wrpspeed ( ) posted Tue, 06 October 2009 at 9:05 PM
i think it needs a "WORK" button.
Morana ( ) posted Wed, 07 October 2009 at 10:57 AM
What I'd kill for is a pause button for those moments when you need to temporarily free up some computer power for something else.
lady-morana.deviantart.com
LostinSpaceman ( ) posted Wed, 07 October 2009 at 5:14 PM · edited Wed, 07 October 2009 at 5:15 PM
Quote - What I'd kill for is a pause button for those moments when you need to temporarily free up some computer power for something else.
It's called CTRL+ALT+DEL>TaskManager>Set Priority>Below Normal
Then you can
CTRL+ALT+DEL>TaskManager>Set Priority>Above Normal
on whatever it is you want to take precidence.
dasquid ( ) posted Thu, 08 October 2009 at 12:21 AM
Quote - > Quote - What I'd kill for is a pause button for those moments when you need to temporarily free up some computer power for something else.
Then you can
Yeah I use that little trick to give my render a boose during the time I am away from the computer like when i am sleeping or at class.
SeanMartin ( ) posted Thu, 08 October 2009 at 8:50 AM
Quote - in other 3d apps (OS X), cmd-. or esc are standard ways to allow user to stop an operation without quitting.  however, they don't work in poser.
I dont think command-. works anymore. Certainly not with Adobe software.
Morana ( ) posted Thu, 08 October 2009 at 9:49 AM
Quote - It's called CTRL+ALT+DEL>TaskManager>Set Priority>Below Normal
Then you can
Thanks, I'll have to give that a try.
